Hi all,
A bit shocked at just how spartan the 2009 DX Patrols are. Anyhow- installing a headlight ON warning buzzer, can't find a suitable pick up point for the lights in the fuse box in cabin (connected the line that says "coil" (useless on a diesel) up to the engine management fuse (tried it on fuel pump fuse too). It appears the fuses are all active as the alarm goes off regardless of which fuse I put it on- 'Tail light' being my principle choice (with the ignition off and lights off- though I tested it with the cabin light and it stopped when the light went off). I am guessing the easiest course is to run it through to the headlight box under the bonnet?
