Page 974 of 1057 FirstFirst ... 972973974975976 ... LastLast
Results 9,731 to 9,740 of 10566
  1. #9731
    Quote Originally Posted by gaddy View Post
    Just a note on the tyre balancing thing .
    Ever noticed the red and yellow dots on the side walls .
    Red is the lightest part of the tyre , and goes to the valve stem
    Yellow should match to a indent on the rim . Cheap rims probably won't have it .genuine rims do .
    One of the fist things I learnt hanging out in the old man's work shops as a kid .
    Thats really interesting, thanks. I have noticed those dots before but never knew why they were there.
  2. #9732
    What the??
    Just checked mine and I see no dots of any colour (Mickey Thompson MTZs) and no indents on genuine Patrol steelies (obviously couldn't see below lead weights though). Checked inside and out.
  3. #9733
    Patrol Freak gaddy's Avatar
    redlands
    What the??
    There just dabs of paint on the tyre and wear of quickly .
  4. The Following User Says Thank You to gaddy For This Useful Post:
    Plasnart (3rd December 2020)
  5. #9734
    483 Post(s)
    Installed new front CV/Axles in the 35 year old GQ Grandpa Spec ute. Wasn’t 100% happy with the full lock smoothness of CV rotation and some wear appearing on the inner seal axle region.
    Usually stick with Nissan OEM parts but....... nearly $2,000 AUD for a set, bugger that!!
    $169 per side from Patrolapart for ‘Roadsafe’ aftermarket brand will have to do
    Keeping the old OEM ones onboard for spares if ever needed out there or if the aftermarket ones explode, hopefully not
  6. The Following 3 Users Say Thank You to MB For This Useful Post:
    Hodge (10th December 2020), Rossco (9th December 2020), rusty_nail (14th December 2020)
  7. #9735
    477 Post(s)
    Nice. I replaced mine a while back too. NTM branded CV’s which is what the OEM ones are for a 1/4 of the OEM price.
    MB (10th December 2020)
  9. #9736
    483 Post(s)
    Cheers Mr Mark Mate!
    Tis a fair dinkum mine field out there finding/trying to make sense of aftermarket quality versus OEM stupidly priced!
    Cooling wise, I’m personally staying staunch on OEM and wherever else possible but near $2,000ish for front axles possibly not needed was ridiculous:-(
    A serious thread on such pros cons for particular aftermarket parts with found unfortunate/fortunate findings experienced would be factually hopefully awesome
  10. #9737
    Expert Mickhead's Avatar
    Oct 2019
    Ok this is strange. Yesterday I lost my dashboard temp gauge. No reading. So i arced up the NDS on the android head unit via the nisbie and it was giving me accurate water temps via the ECU. Disconnected the battery overnight. Drove it this morning, temp gauge not reading but NDS giving real results. Had a closer look and found a temp sensor on the drivers side of the zd30 with a broken wire. Reattached it and the gauge now works. So..... WHERE THE FUK IS THE ECU GETTING ITS WATER TEMP READINGS FROM?
  11. The Following 2 Users Say Thank You to Mickhead For This Useful Post:
    10G (14th December 2020), MB (14th December 2020)
  12. #9738
    477 Post(s)
    Quote Originally Posted by Mickhead View Post
    OWHERE THE FUK IS THE ECU GETTING ITS WATER TEMP READINGS FROM?
    Theres another coolant sender unit for the glow plugs, from this one I would assume.
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (14th December 2020), Mickhead (14th December 2020)
  14. #9739
    Dec 2020
    Sydney
    Today, I picked up and fitted a Tigerz11 Grande 12,000lb winch, and over the past few weeks I have fitted a genuine steel winch bar, rated recovery points to the front, make and installed a table for the rear door, fiited LED lights over the table and into the awning, and last but not least fitted a rear work light.
  15. The Following 3 Users Say Thank You to JamesBrown89 For This Useful Post:
    0-TJ-0 (17th December 2020), MB (17th December 2020), mudnut (17th December 2020)
  16. #9740
    Decided to start on the installation of the Boss rear Coil brackets after work stalled today. launched into the drivers side at 11am, crawled out at 3pm, what a fiddly job it turned into. There are two bots that need to be undone that hold the brake lines I am guessing, so the 4 mounting bolts can be installed in the top plate. On the garage floor, could not get the nuts undone, so drilled them out. Found I actually had a 50mm coil spacer on top of the 300kg Dobinson coil - forgot it was there, so out that came as well as a Firestone 'in coil' airbag.
    All back together on drivers side, sitting down a fair way, have not inflated the BOSS triple airbags yet but think a trip down to Dobinsons in Dandenong in the new year to get another set of rear coils, heavier and longer. Tomorrow i plan to do the pass side as its supposed to be a lot easier than the drivers side. Beautiful simple bracket, well presented kit and instructions including the engineering certificate, happy days.
    Bonnet still sitting there waiting for my attention - maybe after Xmas.
  17. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (23rd December 2020), Winnie (23rd December 2020)
