Results 1 to 2 of 2
Thread: Gu stopped charging new alt still not working
    Nov 2020
    Good afternoon my old alternator blown the sprag clutch so I replaced it with new alt worked fine charging as normal then left the car came back in a few hours alt was not charging checked everything the sense wire getting 12.5 there and the field wire getting 12.v constant but getting nothing of the back of the alt so went and swapped to a new alt again for it to do the exact same thing work normal then when I would go drive the car again nothing coming off the alt checked all fuses nothing wrong there I hve noticed that the battery warning lights that use to come on with the key are no longer turning on at all
    2005 zd 30
    Hi Jimmy, might be best to introduce yourself first before asking any questions,
    no harm done just polite and all.
    Have you connected all the earth wires, etc sounds like youve missed something when swapping them over.
    Any way welcome to the forum enjoy.
    After youre intro maybe post your question in the electrical thread,
    good luck TD
