Page 131 of 136 FirstFirst ... 129130131132133 ... LastLast
Results 1,301 to 1,310 of 1356
Thread: All Things Chev
  1. #1301
    Apr 2020
    Thanks very much.... exactly where I want to look, but I am not sure what I have done with mine.. I am pretty sure a 2nd spring popped off, and positioned like in the pictures you referenced, there is way to much play in my throttle cable..
    I think I might end up goin to one of the local mechanics here Tuesday as he has one to have a look at, to see if there is something I am missing.
  3. #1303
    There is only 1 spring. Have you adjusted the threaded sleeve with the lock nuts - 1 either side of the anchor bracket for the throttle cable? Where are you located?
  4. #1304
    The cable isn't broken inside the sleeve by any chance?
  5. #1305
    Apr 2020
    Turns out the cable had come out at the throttle pedal.. had a chat to the mechanic yesterday and he suggested it..
    Note to self, don't do work on the 4WD when its getting dark, and after some beers...
  6. The Following User Says Thank You to spud027027 For This Useful Post:
    PeeBee (16th April 2020)
  7. #1306
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    OK time to post.
    finally got the truck home after 36 months.
    I'm happy with the truck, but not the time frame, although it doesn't drive well due to the 6L90 being in limp mode, and the accelerator pedal needing too much pressure to use.
    The truck is going to have the air bag replaced thanks to TAKATA, and then it's time to get a cal into the trans.
    Wiring is not to my liking, however it starts and runs, I'll have something to do over the next few weeks.
    I'm also going to do the center console for the new shifter, and looking at what needs to be monitored gaugewise.
  8. The Following 3 Users Say Thank You to poindexter For This Useful Post:
    0-TJ-0 (16th November 2020), MB (14th November 2020), PeeBee (14th November 2020)
  9. #1307
    483 Post(s)
    It’s ALIVE Ralph Mate, Congratulations
  10. #1308
    Apr 2013
    22 Post(s)
    Thanks MB, has been quite a journey, but finally home. the enjoyment starts now.
    I'm also pleased that the hood shuts, and it no longer has a scoop....
    Sort of looks cool in my eyes.
  11. The Following User Says Thank You to poindexter For This Useful Post:
  12. #1309
    483 Post(s)
    She’s a Sleeper Mate, best to keep off Mr Plods Radar for sure
  13. #1310
    Apr 2013
    22 Post(s)
    Well, got the airbag replaced, so the rego doesn't get cancelled.
    The trans is in limp mode, due to the engine rpm and the throttle position sensors not being connected, so its reverse or third gear.....
    But it does sound good,
    I did notice the the p/s pump whines a bit, but I guess that's probably normal, might have a look at the hydroboost push rod adjustment as I think the rears are dragging a bit.
    Need to sus out an auto elec locally, so if anybody knows someone who's switched on, let me know.
    Then it's on to the center console!
    more to follow..
  14. The Following User Says Thank You to poindexter For This Useful Post:
    PeeBee (21st November 2020)
