Page 30 of 96 FirstFirst ... 2829303132 ... LastLast
Results 291 to 300 of 959
  1. #291
    476 Post(s)
    Mudski's High Warn High Mount Rebuild into an ARB GU Bar
    Shocking, you’ve always kept the beast washed and cleaned, even after salty crud from new mate?
    How much do you want for the old pig, and or let’s comp truck it ?
    Insurance time. Write off! I can hear a Y62 calling me.
    Just seen I can still buy a new support panel. I guess I need to strip it down now and get a new panel. What an absolute pain! I wonder if I leave it how long it will last.
    MB (6th May 2020)
  3. #292
    How long is a piece of string Brother :-)
  4. The Following User Says Thank You to MB For This Useful Post:
    mudski (6th May 2020)
  5. #293
    476 Post(s)
    Yeah I know. I really, really don’t want to be doing this though.
    MB (6th May 2020)
  7. #294
    Can't just stip it back clean and rattle can rebuild or too buggered? Hard to tell from pic but doesn't look too bad. . On second thoughts I think she's rooted Ill take it off your hand for ya . .
  8. The Following User Says Thank You to Rossco For This Useful Post:
    mudski (7th May 2020)
  9. #295
    476 Post(s)
    I doesn't look too bad bud I can tell it is as the area is actually swollen, so the rust is on the inside and pushing out. These are prone to do it. Dumb design, the lower tube section where its rusted out is open and free for water to just sit inside it. When I did the body mounts about four years ago I remember the bolts for the front mounts, which go directly through this rusted area, were really rusted and I had to buy new bolts.
    I'll get the die grinder out tonight and have a dig at it and see if i can repair it. Changing this panel over means getting the AC degassed, or I do it myself , removing the entire front of the car pretty much. I have a free TJM OX winch here for anyone who wants to do this for me. Haha!
  10. #296
    Ah bugger rodger, yeah once it starts poping fron the other side no good. Good luck with it lol hopefully come up good enough. .
  11. #297
    476 Post(s)
    Ugh! Just killed my Dremel! Another thing to buy now. Second one I have killed. Both died the same way too. And they don’t get used a hell of a lot...
  12. #298
    Simple.
    A piece of string is twice as long as half its length.
  13. The Following User Says Thank You to jay see For This Useful Post:
    mudski (8th May 2020)
  14. #299
    Maybe look at the Milwaukee die grinder? Might be a little more robust.
  15. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    MudRunnerTD (8th May 2020), mudski (8th May 2020)
  16. #300
    198 Post(s)
    Good idea I reckon. I have a Dremel and find it annoying how small the parts are for work bits - bearing in mind it is more a hobby grinder, than the Milwaukee, which I suppose allows use of the 6mm shank grinding tools as well.
