Results 1 to 9 of 9
Thread: New Shocks
    Feb 2017
    East Maitland NSW
    New Shocks
    HI guys my 2012 ST has 140000 kms shocks seem to be RS
    What brand are a good replacement ?
    Used as every day transport & towing camper trailer on week ends
    Thanks Regards
    Rob Poynter
    334 Post(s)
    Old Man Emu gets my money. OME Sport is very good, mine has 240,000kms on the suspension and still going strong. when they finally die i will go tot he ARB OME BP51s which are next level but at this stage the Sports have done an amazing job.
  3. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    mudski (14th August 2019), Rob Poynter (14th August 2019)
    477 Post(s)
    Yeah OME Sport would be my choice.
    Rob Poynter (17th August 2019)
    May 2016
    lower west victoria
    30 Post(s)
    I'm running Tough Dog adjustables (45mm) and I reckon they're darn good. Ran them on the Madigan and they got blisteringly hot but just kept on going. Great being able to adjust them for when I'm loaded or unloaded.
    Ran them on the old Navara as well, I can't fault them.
  7. The Following User Says Thank You to 10G For This Useful Post:
  8. #5
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Another vote for OME. 170,000 km & still going strong.
  9. The Following User Says Thank You to VK2FMIA For This Useful Post:
  10. #6
    How do you assess if the shockers are operating correctly ? I had a new OME system installed on my patrol from new. At 50,000klm, I pulled the shocks off and found the compression rates varied considerably from side to side. I tossed them for Koni adjustable hydraulic and at 110,000klm rebuilt them- or Koni did, simply replaced the metering discs, and back to square one. The Konis have a 3 or 4 stage adjustment and I found the compression rate side to side was different by 2 clicks on the rear and 1 click on the front. For me, the results have been very different than others.
  11. The Following User Says Thank You to PeeBee For This Useful Post:
  12. #7
    22 Post(s)
    The shocks sole responsibility is to control the spring, converting that kinetic energy to heat.
    If you put your weight on on corner of the vehicle and bounce of it, basically the spring should compress, extend and settle. Any more movement and the shock isnt really working. (Not necessarily faulty, not doing its job)
    96 GQ coil/Cab
    08 G6eT
  13. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    PeeBee (16th August 2019), Rob Poynter (17th August 2019)
  14. #8
    477 Post(s)
    Yeah I got those too and while they are still working, they're just too big in size I think. The front covers rub on the shock tower and the rears hit the spring and are destroyed. Already replaced them once. Not doing them again.
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #9
    22 Post(s)
    You have decent lift and radius arm spacers?
    If that's the case, it's all your fault that it rubs, not the shock
    96 GQ coil/Cab
    08 G6eT
  17. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    gaddy (17th August 2019), Rob Poynter (17th August 2019)
