Results 1 to 9 of 9
Thread: Radius arm spacers
    Jun 2019
    Cool Radius arm spacers
    Gday blokes, has anyone put radius arm spacers in before? how is the easiest way? cheers
    334 Post(s)
    Quote Originally Posted by Jimmytb45 View Post
    Hi mate. fairly easy to do. a bit of stuffing around. you need to secure the front diff from rolling forward so chock it and maybe strap it. Axle stands under the chassis rail on both sides to take the weight of the car. Strap the axle before removing teh radius arms as the sprung weight will want to roll forward. Or jack teh car up to the spring droop. Tie rod off.
    I have a set of spacers in the shed if your chasing some. I run Drop boxes in both cars and dont need them. Brand New and unused. I bought them for a build but went straight to drop boxes.
    Jun 2019
    Ok so jack car up, put axel stands on chassis rail, info one side tie rod and then strap diff to axel stands and chock wheels.. wheels need to be on ground right? So when I undo the radius arm is it huge force pulling diff forward ? Thanks for the offer but I got a set. Thanks any mate 😃
    334 Post(s)
    Given the axle stands are holding up the car and your going to be getting under it i would not be strapping back to eh axle stands. Strap back to the Gearbox cross member of the chassis crossover will be find. Ratchet straps for the win. Remember though you will want the front diff to move forward slightly to allow for eh spacer. A second person will be welcome.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    @MudRunnerTD I could take those spacers off you mate if suits. If you prefer, PM me the details Darren. Just dust them off, could post or just bring them to Licola mate.
    Hate the clearance with 33s to bottom flare arch(2" lift), do not use front flaps but like to get clearance to run my front chains(still be tight though I guess). Do miss the FJ45 for that.
  6. The Following User Says Thank You to Bidja For This Useful Post:
    MudRunnerTD (10th June 2019)
    I installed the 12mm spacers and my 33's still catch on the mudflaps, especially as they have 22yrs of mangling and dont sit dead straight. Apart from that no difference in the drive feedback.
  8. #7
    Sep 2018
    queensland
    3 Post(s)
    question, what is the reason for these spacers?
    sounds like the allow clearance for large wheel any other things they do?
    like for wheel alignment or drivablility?
  9. #8
    Jul 2017
    40 Post(s)
    Might end up cutting away the bottom inner section of flare (plastic gunk), no stock mud flaps now and might fix some rubber flap to side steps one day. The clearance is a joke.
  10. The Following User Says Thank You to Bidja For This Useful Post:
    PeeBee (11th June 2019)
  11. #9
    Jul 2017
    40 Post(s)
    @Fireblade Yeah bit of clearance and coils would drop squarer off towers (not much change for 2" lift).
    Don;t thinks would change alignment geometry.
    Driveability??? @PeeBee mentioned
  12. The Following User Says Thank You to Bidja For This Useful Post:
