threedogs (19th April 2019)
@Hodge only paid $276 with a discount they had and they threw in a 6 pack cooler
Think I did ok,?
Finally got around to permanently mount the solar controller and after a lot of stuffing around looking for a spot I settled on this spot , made a bracket / base plate out of some steel and bolted it to an existing bracket that holds a relay (two bolts) .
Can only get to the two outside fixing points on the controller but it will end up with two small bolts and a small dob of silicone holding it in place .
Small job, big result. I finally did the barn door extension for the left side.
I'm still procrastinating as to where to mount my controller, the same Victron unit. I considered mounting it in that same spot, but was a bit worried about the heat it generates, and the lack of quick access should I need to get to it fast. Maybe I worry too much, but mounting it on my cargo barrier is my preferred option at the moment.
