17th March 2019, 07:04 PM
Add On to my home made racks
Hi Guys, add more rails to my rack system, So i can put my cheapo ebay "MaxTraks" on my roof . please note it's not easy drilling S.S. bolts , wd40 doesn't help. each hole cost one drill bit at $9 dollars lol done now
The Following 3 Users Say Thank You to altech For This Useful Post:
MB (17th March 2019), MudRunnerTD (17th March 2019), rusty_nail (17th March 2019)
17th March 2019 07:04 PM
18th March 2019, 12:39 PM
Key to drilling stainless is very low speed, too fast or using WD40
will just melt drill bits. imho
18th March 2019, 01:54 PM
threedogs
And gotta keep it cool. Do not get the SS hot or you will just bugger up your drill bits. Use cutting oil or paste too.
The Following User Says Thank You to Brissieboy For This Useful Post:
18th March 2019, 04:55 PM
threedogs
that is was I thinking, buy a high speed drill. then you must drill at high speed. Thanks for the advise cheers Alex
The Following User Says Thank You to altech For This Useful Post:
threedogs (19th March 2019)
