Hi all.
As the title says.
I'm at a lost as where to start. Only thing I can think of is the gear, that's if these have one.
Hi all.
As the title says.
Check speedo gear / sensor on transfer case. Easiest to start with. Takes 5 minutes.
Thanks Hodge. That's the starting point...
Yeah remove the sensor and see if the teeth on the gear are stripped. If you have a black gear, I have a spare one here you can have. Nissan have used different colour gears which denote how many teeth on the gear. They've have done something smart for a change....
jay see (19th December 2018), MudRunnerTD (19th December 2018)
Or shoot me your VIN. I can see what gear it is you have. But removing the sensor can literally be done in a single breath. Its that quick and simple.
jay see (20th December 2018)
Or check my recent Speedo pinion swap.
http://www.nissanpatrol.com.au/forum...d.php?p=772895
Lol. I just realised. John's GU is auto. Some of the auto models use a different speedo driven gear setup to the manual trans.
So I'll go by Hodge link and see where that get me.
Hodge I can't remember you manual or auto.
His is manual mate. The physical setup is the same, or very similar between the manual and auto speed sensors, its more so the shape and size of the gear. I do know that some models use the same type of gear as the manual models though. But never figured out which ones it was. Ge me your VIN and I can find out.
