17th August 2018, 04:58 PM
Rear bar suitability
Hi all it’s probably here somewhere but after much searches ng they all started looking the same. Just curious weather anyone knows weather the rear bar off a series1 will fit onto a series4. I have one I can get but don’t want to take my standard plastic crap off do a 1/4 chop to find it doesn’t fit. Also do you know weather the 08 series4 has any air bag sensors in the rear 1/4 that will be an issue when the chop is being done. Thanks legends.
Remember laughter is the best medicine. If you don't laugh you die.
![Smileyvault Cute Big Smiley Animated 013](images/smilies/smileyvault-cute-big-smiley-animated-013.gif)
17th August 2018 04:58 PM
17th August 2018, 05:21 PM
I doubt the early bar will fit without any mods done to make it fit. I dont believe the Patrols had rear sensors too. Happy to be corrected on that...
17th August 2018, 09:10 PM
Moderator
A rear quarter chop is very unusual in a GUIV? Why do you want to do that? On a GQ it is done because rhe wheel arches are tiny and the rear quarter fouls on 35s but for the most part a GU has huge wheel arches and its not really required. Not sure i have even ever seen it done on a GU to be honest.
I dont think the bar will work around the larger tail lights but if your doing a chop then just make a tube bar mate.
Check out my Toy -->
Rogue Dung Beetle
17th August 2018, 10:36 PM
MudRunner it’s not the factory bar the bar is a custom made steel protection job that was made for my mates series1 it had to have 1/4 chop to make it fit snug and sit up higher on the back of the vehicle to give it extra departure angle. My main concern is the width and the distance of the side wing where it wraps around toward the rear tyres. Cheers for the info appreciate any feed back the more the better
18th August 2018, 07:37 AM
Patrol grub
If it's your mates, I'm going to assume you have access to the bar in question and/or the vehicle it's fitted on right now...
In saying that, they're not hard to take off and on so, maybe slap it on your car and have a look? Best way to find out I guess.
18th August 2018, 10:18 AM
Moderator
Patrol grub
The chassis and body are fundamentally the same so it really will just be the lines of the trim. ie. The tail lights. As Hodge said above id just bolt it up and see how it looks.
If you can post a couple of pucs of it here i might be able to see anything that will get in the way.
Rogue Dung Beetle
18th August 2018, 09:38 PM
Ive put a series 1-3 ARB rear bar on a series 4, I had to cut a section off the rear chassis rail where the tow hook goes because series 1-3 have a recessed step, series 4 the bar sticks out further, that should be the only difference between the body’s
Flares might be different as well, series 4 flares are a little chunkier
Just another Blue over Silver GQ with another TD conversion
20th August 2018, 07:40 PM
Awsome thanks all I was talking to him today and we decided to do what you are suggesting and we are going to try take it off and see how it looks appreciate all your help folks.
