Page 831 of 1057 FirstFirst ... 829830831832833 ... LastLast
Results 8,301 to 8,310 of 10566
  1. #8301
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Haha it seems I created a side story , Glencairn is an area nth of Licola , between Jamieson rd & middle ridge intersection on top of the hill - it's the bit down the bottom - there's a section of bitumen about 100mts long through it . BTW I carted logs out of there when I 1st started . I assume we all know what BTW means ? @Rossco ?
  2. The Following User Says Thank You to Sprock For This Useful Post:
    Rossco (15th April 2018)
  3. #8302
    Best times wazza? Break the winch ? ? . . .
  4. #8303
    Repaired the flare and torn tabs broken last weekend, also fixed the dent in the drivers side plastic scuff pad and polished out the panel dent so its hardly noticeable. Removed the 200a/hr battery that dropped a cell, also on the same weekend as the flare damage, and now looking for a replacement, thinking along the lines of the Optima D31T, probably 2 of them. Should have enough grunt for the rear winch and also run the fridge and coffee machine nicely.
  5. #8304
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Call around to my head office over in Rowville. They have a battery called an Ultimate UL-230
    It’s a huge sucker with 230 ah AGM deepcycle
    https://www.mpower.com.au/products/b...agm-deep-cycle
  6. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    PeeBee (15th April 2018)
  7. #8305
    Those pics make sic sick with jealousy!!!
  8. #8306
    Thanks for that, they are not far from , maybe 10 minutes. Can't see a CCA rating though - this is part of the 'picture' to some degree. Vehicle can sit on maintenance charge for a couple of months and not move, then out we go and give the battery a work out for a weekend and back to sleep. Concerned about sulphation, and yes use a CTEK charger plus an addition de-sulphation device as well. No doubt a few bucks for this monster so need to be sure its the right one and that my 'useage style' does not kill it prematurely. I will give the office a call in the morning and have a chat.
    Yeti's Beast (15th April 2018)
  10. #8307
    That little pinch was an eye-opener for me as the vehicles simply crawled up it yet it was difficult to walk up. I also went straight up but had the benefit of Darren guiding me - was headed for the chicken track until firmly directed back up the ugly bit. These patrols are incredible beasts. Another great weekend, and walked away with more confidence and skills I believe.
  11. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudski (15th April 2018), Winnie (15th April 2018)
  12. #8308
    Not much going to be happening to the trol for a little while. It's a a point where it's doing what it needs to do.
    Time to put some coin and time into the R8. Want to get it registered and looking schmick before the end of the year.
  13. The Following User Says Thank You to jay see For This Useful Post:
    mudski (16th April 2018)
  14. #8309
    Aug 2016
    Jimboomba
    4 Post(s)
    Let’s see if this works
    https://www.dropbox.com/s/1ewtfdl12z...02016.pdf?dl=0
    If you call, Ask for Albert and I will email him to let him know. I work in Qld
    That battery has a cca rating of 987 cca
    If it’s let sit on the Ctek that should be fine as they go into hibernation after 10 days. We often sell these for emergency generators so they sit on float charge mostly in that application. We also have a Gel version
  15. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    PeeBee (16th April 2018)
  16. #8310
    Where is the video of that rocky climb
    this one mate? =P
  17. The Following 6 Users Say Thank You to rusty_nail For This Useful Post:
    Ben-e-boy (16th April 2018), GQtdauto (16th April 2018), jay see (16th April 2018), MB (16th April 2018), Rossco (16th April 2018), Yeti's Beast (16th April 2018)
