Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: Let's talk Rooftop Tents
  1. #31
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Was wondering what that tractor was for .
  2. #32
    Is there a chance you could show us how you mounted the ARB tent to it ?
    I was at ARB and the bloke didn't know how you'd mount it to the platform using their channel system. Their display was on the ARB rack, installed with U bolts.
    Just a plate mate.i bought mine like it but heres a pic of the slidey bits that go into rails of rooftop the bolts that hang down just have a playe that sits under the rhino rack.....cheers...mine is a kings tent not an arb,diunno if that makes a difference
  3. The Following User Says Thank You to Avo For This Useful Post:
    Hodge (9th November 2017)
  4. #33
    177 Post(s)
    Thanks for that mate. I think they're the same system underneath. I'll have to check.
    @VK2FMIA Looks like you also have the Rhino platform system. Unless I'm wrong?
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Same system on the ARB as the Kings using Rhino racks.
    Sent from my campfire using smoke signals.
  6. The Following User Says Thank You to VK2FMIA For This Useful Post:
  7. #35
    Just spoke with Sprock and Grimme's is called a Bundutop from www.bundutec.com.au in Moorabbin. About $3800 apparently.
    Maglinolini or whet ever they are called make won of the better one .
    Anything made in Sth Africa or NZ are good value
  8. The Following User Says Thank You to threedogs For This Useful Post:
    GQtdauto (13th November 2017)
  9. #36
    Mar 2017
    Cairns
    At the risk of resurrecting a thread that’s been stagnant for a couple of months, have you guys seen the stand from muddy4x4accessories? It looks pretty neat and let’s you drive off and leave your tent behind
  10. The Following User Says Thank You to Kevrana For This Useful Post:
    GQtdauto (23rd January 2018)
  11. #37
    Mar 2016
    10 Post(s)
    Quote Originally Posted by Kevrana View Post
    Wonder what takes longer?. Setting up the stand or packing up the tent?. Takes me 15 - 20 mins to pack my RT up & I would not be keen to leave 2 grand worth of tent for someone else to steal!.
    Not a bad idea if you would like to leave your Rooftopper at home between trips though.
  12. #38
    Mar 2017
    Cairns
    Quote Originally Posted by VK2FMIA View Post
    Looks like it would take a fair bit of stuffing around to set up and pack away.
  13. #39
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Compared to erecting a normal "on the ground " tent its possible a bit less trouble. I wonder how wind (willy willy ) resistant it is? The only thing pegging it down is the two tie downs holding the floor level. There doesn't appear to be any peg or rope holes in the stand at all. Normally on an RTT you have the car which is a fairly good anchor, and also stops the wind getting under the tent.
  14. #40
    For those that have Faceache...... Yes it does look like a fair bit of stuffing around. But does mean you don't have to pack up to go anywhere
    https://m.facebook.com/story.php?sto...59309281219930
