Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Steel Vs Alloy Rims for offroad use.
    I would probably flog off the alloys and buy some steel rims if I ever upgraded to a GU.
    The video played ok for me.
    Do I detect a lotto win, go on go the U
  2. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    GQtdauto (7th December 2017), mudnut (7th December 2017)
  3. #12
    176 Post(s)
    I love the look of the GU4 ally rims. But considering they're 17's, tyre prices are inflated. Well they were when I was in the market for a set. So set of 16 steelies, was a no brainer. Plus its easier to find 16" tyres should one be desperate.
  4. The Following 2 Users Say Thank You to Hodge For This Useful Post:
  5. #13
    84 Post(s)
    Wouldn't it be noice, but no!
  6. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    GQtdauto (7th December 2017), threedogs (12th December 2017)
  7. #14
    My 5 cents worth... If the discussion is indeed Steel Vs Alloy Rims for offroad use then the answer is unequivocally Steel.
    Alloys evolved for two reasons, one, Bling which is totally irrelevant offroad and two, reducing the unsprung weight for improved handling, high speed braking and low frequency damping which are almost irrelevant 'off road' but very desirable qualities "onroad".
    Steel increases unsprung weight and the advantage of that 'offroad' is better damping of high frequency vibrations.
    As far as rim damage/failures then steel is more likely to be salvageable to at least some extent while alloy is much more brittle and will tend to crack or have a catastrophic fail rather than deform.
    The different expansion rates between steel and alloy aren't a real biggee IMHO but the advantage would lay with Steel if the rims are getting a lot of heat transfer from a large amount of work on low pressure tyres
  8. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    MB (7th December 2017), mihit (12th August 2022), mudnut (7th December 2017)
  9. #15
    I learnt a new word and true reasons today, thank you as always ET good man :-) I do ‘Unequivocally’ agree with your perfectly worded advice above.
    I dare say my personal experiences of old with dangerous as hell alloy rims I may have used swear words like ‘poopoo’ they are and to stay well away from rocks offroad with em :-( Light cracks may be started on them whilst offroad and very well may let go on a highway home days later!!
  10. The Following 3 Users Say Thank You to MB For This Useful Post:
    mudnut (9th December 2017), rusty_nail (7th December 2017), the evil twin (7th December 2017)
  11. #16
    Best $95 Dynamic Steelies (Cheaper than ROH) per corner ever spent some years ago on the Golden Gramps GQ
    https://youtube.com/shorts/gk8bKeN2ADA?feature=share
  12. The Following 3 Users Say Thank You to MB For This Useful Post:
    Bidja (11th August 2022), mihit (12th August 2022), Rossco (11th August 2022)
