Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Is this a normal or a problem? (Pics)
    May 2016
    8 Post(s)
    ITs a feature not a Fault !!!!
  2. The Following 4 Users Say Thank You to Tip12345 For This Useful Post:
    Bigcol (14th November 2017), dom14 (15th November 2017), mudnut (13th November 2017), threedogs (13th November 2017)
  3. #12
    Legendary dom14's Avatar
    38 Post(s)
    Does it smell, like grease or oil. If too much grease has been added to the bearings and the like it can seep out when hot and is not such a problem. If it smells like diff oil, you have a leaking axle seal and this should be dealt with, as it can dilute the grease and destroy its effectiveness.
    Few years back I ended up adding too much grease to those bearings and grease was oozing out of the scrapers.
    On top of that I did the stupid thing of applying a thin layers of sealant to the bearing cap shims as well.
    One of my axle seals are leaking slowly now and need to be done soon.
    A messy but quite DIY'able job as I've been told by MudrunnerTD by his threads.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  4. #13
    38 Post(s)
    No smell that I could detect. Pretty sure I'd pick a diff oil smell. Car has been used a lot harder over the past 3 or 4 months than in all the time I've had it. Little doubt that the hubs have run hotter during this time. Also running with hubs locked for weeks at a time. It is possible I over did the grease a bit, but it was a while ago so can't be sure.
    I'm not sure smell's the best way to detect front CV axle leaking slowly. Mine does leak(one side) but I smell no diff oil.
    May be 'cos I overgreased the king pin bearings?!
    Cheetah Outreach
  5. #14
    84 Post(s)
    Drop the lowest one of the bottom swivel bearing bolts and poke a bit of stiff plastic in there. If there is diff oil it should dribble out.
  6. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    dom14 (15th November 2017), GQtdauto (15th November 2017)
  7. #15
    38 Post(s)
    That's a good tip. Thanx mate.
    Cheetah Outreach
