Results 1 to 10 of 15
Thread: Is this a normal or a problem? (Pics)
    178 Post(s)
    Both sides
    The ball joints are dry to the touch as is the 'stained' dirt.
    Normal, something to keep an eye on or something needing work now?
    My gut feeling suggests it's not a big deal & to just keep an eye on it whilst we tour Tassie over the summer & if it gets worse to get it fixed before we cross the Western deserts next year. What say you?
    Expert Skitzyrex's Avatar
    Jul 2013
    Can’t really help if it’s a big problem but I’d be cleaning it all up with some degreaser and a brush. That way you have a better judge on how long it takes to seep out.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  3. The Following User Says Thank You to Skitzyrex For This Useful Post:
    Cuppa (13th November 2017)
    Yeah think your pretty much on the money, don't stress and just keep an eye on it . . .
  5. The Following User Says Thank You to Rossco For This Useful Post:
    84 Post(s)
    Does it smell, like grease or oil. If too much grease has been added to the bearings and the like it can seep out when hot and is not such a problem. If it smells like diff oil, you have a leaking axle seal and this should be dealt with, as it can dilute the grease and destroy its effectiveness.
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Cuppa (13th November 2017), dom14 (15th November 2017)
  8. #5
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Mines twice that bad on the GQ and I'm not worried yet but probably should get it done before the cape and Kimberly trip next year .
    Mine started to leak a bit after the wheel bearing was done and I'm sure it's grease , don't clean it off leave it just in case you upset the seal would be my advice .
  9. The Following User Says Thank You to GQtdauto For This Useful Post:
  10. #6
    178 Post(s)
    No smell that I could detect. Pretty sure I'd pick a diff oil smell. Car has been used a lot harder over the past 3 or 4 months than in all the time I've had it. Little doubt that the hubs have run hotter during this time. Also running with hubs locked for weeks at a time. It is possible I over did the grease a bit, but it was a while ago so can't be sure.
  11. #7
    84 Post(s)
    Yep. Since you know how bad diff oil pongs, it should be. OK. Mine has been weeping on and off for 3 years or more.
  12. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    Avo (12th November 2017), Cuppa (13th November 2017), GQtdauto (12th November 2017)
  13. #8
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Maybe I won't get it fixed after all if yours has been weeping that long .
  14. #9
    As long as it's not wet to touch or dripping fluid I'd leave it be.
  15. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  16. #10
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    same as above - if it is dry to touch, then clean it up completely, and have a look every 2nd day
    if it is starting to weep - then worry about it
    but it looks ok, so no stress yet
  17. The Following User Says Thank You to Bigcol For This Useful Post:
