Results 1 to 4 of 4
Thread: Clutch issues
    Advanced my93maverick's Avatar
    Oct 2015
    Clutch issues
    Hey guys i have an issue with the clutch, we were 4wding out wallaroo the clutch first went a little soft and would not engage a gear so we stopped and had a look, the slave cylinder was still moving so we tried bleeding it at all 3 locations and its just gone completely soft and now the slave cylinder will not move, iv tried bleeding again today with no success just wondering if anyone has had the same issue or might know what it is cheers guys.
    Sent from my GT-I9505 using Tapatalk
    May 2016
    8 Post(s)
    mmmm sounds like its a gearbox out type situation ! Have you tried pushing the slave cylinder piston back into itself ? and pumping it back out with the clutch pedal . what tools do you have ? try clamping off the slave cylinder (the rubber hose with a brake hose block off tool ) and see if the master builds up pressure . could be the master cylinder? you need
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    Dont wanna make myself sound dumb... but is there water in the hydraulic still? If the reservoir was contaminated and you didnt completely bleed all of it out of the lines then it could/ve evapourated in the steel line that runs behind the engine. My 2c anyway
    1992 Nissan Safari Granroad LWB TD42 after market turbo RE4R03A (for now) 3" straight pipe
    Oct 2015
    Sorry guys only just got back online lol, i have plenty of tools for the job just dont know which one to do the master cylinder doesnt even let any fluid out with the line off and pumping the clutch
    Sent from my CPH1701 using Tapatalk
