Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 115
Thread: PWM or MPPT.
  1. #81
    So this system is wicked.
    So the weekend has been over cast as hell.. Near raining..
    The cf50 is connected to the system as a freezer to cycle the system..
    Its going that good even on these crappy days im thinking ill leave the 120w folding home..
    Yesterday put in 10ah at around 18v..
    Todays a brighter day so will see how its proformed today..
    186wh produced today
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Here's mine for the day
  4. #84
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Isn't that much the same as yesterday Westy ?
  5. #85
    Im only metering input with the watts up meter so voltage varies.
    So all though it put in "10A" it may have been from 13v up to 20v..
    So by reading the watts input it doesnt matter the voltage or amperage as its the sum of both..
    But yea, both days have been similar.
    Only just reached a peak of 100w input threw the day, so still got a lot of headroom..
    snip...
    Yeah, I know what you mean.
    I have 4 x 25 watt semi flexible panels feeding a Tracer MPPT reg and that outperforms my prev 120 watt (2 x 60's) folding setup plus is 1/2 the size folded up and about 1/4 the weight.
    Ended up selling the 120 watt about a year ago as I wasn't using it.
  7. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (16th May 2017)
  8. #87
    So today was a shit day lol..
    97wh lol..
    So im taking my portable with me lol..
  9. The Following User Says Thank You to BigRAWesty For This Useful Post:
    GQtdauto (16th May 2017)
  10. #88
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yeah quantity wins every time , the 600 watt I had on the van kept three batteries going no matter what the weather and most of the time it was only charging two anyway .
    I've heard 250 watt of solar minimum per 100 amp of battery covers you on overcast days but only just and depending on usage .
  11. The Following User Says Thank You to GQtdauto For This Useful Post:
    BigRAWesty (17th May 2017)
  12. #89
    Well atm the van had 200w pannel and 120ah battery.
    So adding my 120w gets me around the 2.5-1 ratio..
    I did read 2-1 is good.. but more is better as you say..
    Best bit is both are 22v pannels.. so ive set it up to run in parallel so itll be 14A @ 22v..
    snip...
    Yep, if all panels are the same Voc (open circuit volts) that idea will work tickety boo
  14. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (18th May 2017)
