Results 1 to 4 of 4
Thread: 4.2TD code 21 F/Inj TmgF/B
    Nov 2013
    QLD
    Hi everyone, I had my engine light popping up a week ago. My ECUtalk told me that the cause was code 21. I went to a mechanic and he checked it out. He told me he cleared the code and cleaned the sensors. Should be all good. 400km, same thing happens. But it isnt constant. Sometimes it popsup right away and other times the next day after clearing the code through my ECUtalk. Any recommendations on what I can do myself to fix it? What to look for etc. Google hasnt helped much and I am missing the related part from my service manual.
    I am in Mulgrave (Vic) atm and will be travelling to Adelaide soon. Any recommendations on reliable and affordable mechanics is welcome to.
    177 Post(s)
    It's possibly a TCV connection or connection to #1 injector.
    Check connections and hit them all with some Crc of similar . Try that first.
    Connector is under the pump and you'll invent new swear words getting to it.
  3. The Following User Says Thank You to Hodge For This Useful Post:
    dannypatrol (13th May 2017)
    Nov 2013
    QLD
    Thanks, I will have a look
    177 Post(s)
    Quote Originally Posted by dannypatrol View Post
    Good luck.
    Mine played up few weeks after I bought it. car had a lot of corrosion underneath which got into electrics too including that plug. Was a bit corroded and was messing with the ecu and I kept getting the error.
