Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 71
Thread: Clearview mirrors
  1. #41
    Oct 2010
    Old Bar, NSW
    Macca
  2. The Following User Says Thank You to macca For This Useful Post:
    GQtdauto (3rd May 2017)
  3. #42
    Oct 2010
    Old Bar, NSW
    @macca, it might be wise to take some measurements if you're mounting the complete Chevy triangle to another. ADR says they can't be more than 250mm outside the widest part of the vehicle if not towing.
    My driver's side is about 5mm over that.
    Phew 220mm. That was from the box/pod body line.
    Macca
  4. #43
    Oct 2010
    Old Bar, NSW
    Coffee time
    Macca
  5. #44
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    The wagon doesn't have that advantage..
    John
  6. #45
    Aug 2014
    Perth
    10 Post(s)
    Does Clearview supply the correct brackets to mount to the GU if you buy their expensive mirrors or do you have to get that fabricated yourself?
  7. #46
    Morayfield, QLD
    Quote Originally Posted by gubigfish View Post
    Yes, you can buy the Clearview mirrors for GU but they don't have the blinkers because there's no factory wiring for them.
    John
  8. #47
    Oct 2010
    Old Bar, NSW
    @gubigfish
    My guess is they would replace the OEM mirror simply swapping one for the other and the wiring plug will match what's in the car too.
    For the money that's what you would expect.
    Macca
  9. #48
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yes , Clearview are model specific and are just a simple bolt in and plug in job .
    Checked my distance for the mirror and I'm under the 250 mm , GQ sticks out about in the rear side above the back wheel and if you take the flares as the widest part of the car I'm under easy .
  10. #49
    Dec 2016
    Northeast Victoria
    41 Post(s)
    When are you going to paint it ?
  11. #50
    Oct 2010
    Old Bar, NSW
    It was hanging up to dry mate.
    Coat of cold gal grey and black the bits that are seen.
    Its all on and usable now, have a 400klm drive this weekend so be interesting to see if I can see.
    Macca
