G'day, having a few dramas with the uncles GU, car overheated a few weeks back found a water leak from the turbo cooling pipes, ordered genuine replacements & gaskets etc. fitted tipped up with coolant and bled system, car started overheating, figured still air in system tried bleeding again, no luck!! Told uncle to take to cooling system specialist, was diagnosed with blocked Radiator, bought new rad & thermostat to be sure, fitted bled system still overheating, thought maybe faulty new thermostat, removed & fitted dummy thermostat still the same, replaced rad caps, still the same, now I'm pretty much over it just thought someone else may have experienced the same 👍
