Results 11 to 20 of 23
Thread: Fail to start.
    Quote Originally Posted by brooks View Post
    Please expand PMD, do you mean injector pump is mechanical. yes it is a brunswick conv.
    Why not give Scotty a call at BD and outline the issue - regardless of whether you elect to go with them or not, they will likely have come across this already.
  2. The Following User Says Thank You to PeeBee For This Useful Post:
    brooks (17th February 2017)
  3. #12
    North brissy
    Pmd- pump mounted driver.
    They were fitted on the later chev engines with stanadyne ds-4 pump. Basically they have some basic electronics for control of fuel. It has a small loom with 4-6 wires from memory. It is fairly common for these to be remote mounted as they are factory fitted to the pump and the heat just kills them.
    But I am unaware of brunswick using these as last time I spoke to them they removed them and just put them to the side and used the earlier ds-2 pump as they are mechanical and easier as such for them to use with their conversions.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    MB (16th February 2017)
  5. #13
    That could be handy Mat, wonder if they'd maybe sell them cheap if they're just laying around. I guess they might also flog them back to the yanks to recoup some costs. Just thinking if ever our pumps were to crap themselves could be an option if they're any good when installed and setup correctly?
  6. #14
    Advanced brooks's Avatar
    Mar 2011
    Perth WA
    this has a mechanical lift pump on RH front of block. appears to be working ok.
  7. #15
    Mar 2011
    Perth WA
    the link is quite interesting, thanks. mine runs good when started but will that cause no start when hot.
  8. #16
    Mar 2011
    Perth WA
    thanks will definitely carry a water bottle, how will water go on the heads though, hope they won't crack.
  9. #17
    Ok, I am out on this one. Mine is electrical lift pump on chassis rail, pumps at 14psi.
  10. #18
    Feb 2012
    Camden, NSW
    I think he means to just pour water on the injector pump housing.
  11. #19
    North brissy
    Will be fine mate. Just use room temperature water. And pour it on slowly.
  12. #20
    North brissy
    Quote Originally Posted by Turtle_au View Post
    I do but brooks concern is warranted at the ip is in the valley of a 6.5 chev. So pouring water on it means water in the valley.
