Can't believe what I'm hearing.
Feel for you mate.
Like the Jamaicans say.
Let get together and feel alright.
Feel for you mate.
Maxhead (26th September 2016)
BigRAWesty (27th September 2016), Clunk (27th September 2016), threedogs (27th September 2016), Woof (27th September 2016)
			Hey mate, it is certainly possible and has happened before where a hydro lock doesn't necessarily lock up from the liquid when it enters, especially in small amounts like in my situation.
It is possible that the oil has entered the engine causing number two to restrict and cause the conrod to bend (Wouldn't know yourself this has happened). The vehicle was not driven afterwards until the very first hill causing stress and ultimately breaking the conrod.
All theory of course until I can get this engine out and assess the crank properly.
So far the crank looks fine and so far the damage looks only to be caused by number 2 piston and as you can see in the pics the tell tale signs of a severely bent conrod shows all signs of a lock.
We know for a fact a litre of oil went into the engine.
We know for a fact it was also being burnt as you mentioned above.
I have many bends in my IC piping and I also have a silicone 3" reducer to 40mm going directly into the OEM elbow to inlet manifold. When I first found out I lost oil you may remember pulling the piping off to find a substantial amount (couple of tea spoons) pooling in the reducer just before the intake which could feed significant amounts into the chamber(s).
Also, I can confirm when running my own tests that the old turbo's leak was getting worse after the engine was running for 30 minutes.
All theory at this stage but so far it is indeed very very plausible pending crank inspection of course.
growler2058 (27th September 2016)
				FWIW it may have been an overpressure rather than a total lock IE sufficient oil in the chamber to raise the cylinder pressure enough to cause the initial damage... then, tick, tick tick, BOOM... just like a... nah... better not say it
AB (27th September 2016), growler2058 (27th September 2016), Winnie (27th September 2016)
				mudski (28th September 2016)
1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
