Results 1 to 4 of 4
Thread: GQ - TI - Rear Stabilizer Disconnect Question
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quick Q on the GQ TI Rear Stabilizer Disconnect
    Firstly, does anyone know how #1 in my pic comes off, I assume undo the 4 bolts but what holds the cable in?
    Secondly, anyone know the best method of replacing the shaft with the ball joint that attaches 2 the rear stabilizer bar ( Pic 2 )? I assume this part can't be bought
    Toddie
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Easiest way to remove cable from unit without removing cable from car is to pull cover off after manipulating unit from bracket (yes it is a Bugger to do) once out cable and rod can be removed.
    Don't know if you can get new replacement maybe try Nissan, when I broke mine complete units were $900 so I welded on some shock eyes and reconfigured sway bar
  3. The Following User Says Thank You to liftlid For This Useful Post:
    NissanGQ4.2 (15th August 2016)
    Aug 2010
    17 Post(s)
    Quote Originally Posted by liftlid View Post
    Yeh seen your post on here with the shock eyes, theirs gotta be something simpler than that
    Nov 2010
    6 Post(s)
    Yep $900 bucks simpler, unless you can get 2nd hand
  6. The Following User Says Thank You to liftlid For This Useful Post:
    NissanGQ4.2 (16th August 2016)
