Results 1 to 10 of 16
Thread: Flat remote.....again.
    Feb 2016
    Just wondering if there is a fix for new batteries going flat in the Central locking remote??
    Ive had the car for about a year and all was fine with the remote until a few weeks ago when it stopped working. I replaced the battery and its flat again within a week....
    Ive seen it mentioned on a few Forums, but haven't seen a fix for it.
    I just want to know if its a trip to Nissan for a new remote and a reprogram?????
    Any help or info appreciated..
    Ad
    Legendary happygu's Avatar
    I would check to make sure that the battery is touching the contacts in the remote properly, and that the contacts are clean and have enough tension. Check the battery voltage and see if it actually is low.
    I would also try a second battery, and check it for the correct voltage with a multimeter before you install it, and see if it does the same.
    Then you will definitely know what to do next.
  3. The Following User Says Thank You to happygu For This Useful Post:
    AD07 (5th August 2016)
    477 Post(s)
    Yeah very common issue with the OEM remotes. I ended up ditching mine and installing an aftermarket kit for around $90, about two years ago, and the battery has just started to go a bit flat now.
    Ballarat, Vic
    178 Post(s)
    I guess I must be a luddite, have never had a vehicle with central locking & can’t say that it’s something I’ve ever felt I needed. Just something else to go wrong.
    Whenever any ST /Ti model owners have an issue that us ‘belts & braces’ DX owners ‘miss out on’, I have a smug little smile to myself ......... but then I recollect how much quieter those models are to ride in compared to mine - one day I’ll have to ‘upgrade to sound insulation to a standard that many of you take for granted.
    are you 100% sure it a flat battery @AD07
    well it's either that or the MAF sensor
  9. The Following User Says Thank You to Clunk For This Useful Post:
    mudski (6th August 2016)
  10. #7
    Sep 2015
    Walvis Bay, Namibia
    Might be a faulty button on the remote making permanent contact?
    Sent from my SM-T531 using Tapatalk
  11. #8
    Jul 2013
    3 Post(s)
    I have the same problem with mine, Nissan are expensive to replace and it is cheaper to use a mobile lock smith that does vehicle remotes. Roughly $250 each from memory.
  12. The Following User Says Thank You to Bush Ranger For This Useful Post:
    AD07 (8th August 2016)
  13. #9
    477 Post(s)
    Bahahahha! Or the belt tensioner...
    Clunk (8th August 2016)
  15. #10
    Feb 2016
    Pretty sure mate....I just assumed as the remote got worse over the last few weeks, then stopped . I replaced the battery , then all was good.....for a while.
