Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Headlight playing up.
    Evening all.
    The last few days one if my headlights doesn't want to work unless I give it a firm hit on the glass.
    I've tried giving the wiring a jiggle and unplug and take out the globe and it continues to not work.
    What else could I look at
    Sent from my XT1033
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    my passenger side one does that, comes on, then go over a bump - goes out, another bump, comes back on
    checked wiring
    checked plugs
    nowt wrong with either
    changed globe
    still does it
    I live with it
  3. The Following User Says Thank You to Bigcol For This Useful Post:
    jay see (19th May 2016)
    84 Post(s)
    Sometimes the element is blown but touches again. Try an new globe or try the other one. Just be careful not to leave a fingerprint on the glass.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Start with a better description of the problem.
    What doesn't work? low beam or high beam? is it both sides?, does the high beam warning light in the dash work?, what glass do you hit..... windscreen?
    I'm guessing it's a GU we are talking about?
    OK. I need to go out soon, so I swap the globes over tomorrow.
    Sent from my XT1033
    ... and check the earth and the earth pin in the plug
    Legendary dom14's Avatar
    38 Post(s)
    Evening all.
    Sent from my XT1033
    I had a similar problem with mine. Unplug rear and closely examine the socket.
    There's a high probability the socket contracts are corroded or dirt preventing the proper contact.
    I replaced the plugs. I don't have to bang on the headlight anymore.
    http://www.ebay.com.au/itm/H4-HEADLI...sAAOSwT6pV3dib
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  10. #8
    38 Post(s)
    Quote Originally Posted by Bigcol View Post
    checked wiring
    checked plugs
    changed globe
    still does it
    I live with it
    It's an electrical problem. Better fix it straightaway.
    Cheetah Outreach
  11. #9
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    you think so Dom...........?????
    been to Auto Electricians several times, and they cannot find the fault
    new globes
    plugs have been replaced
    new up graded wiring harness for head lights installed
    new relays
    new globes
    new fuses
    replaced Headlight Wiring Loom upgrade with an even better one
    still does it every now and again
    not often
    maybe once a month for about 20mins.................
  12. #10
    Well do.
    Yeah, well do tomorrow.
    Funny thing is that the wife came home with a blow headlight and the spot light out the back blow a globe too.
    Well that is the 3.
    Went out a few times tonight and the lights both where working. Will still swap them over tomorrow
    Sent from my XT1033
