Page 70 of 101 FirstFirst ... 6869707172 ... LastLast
Results 691 to 700 of 1003
Thread: Hodge's new 4.2
  1. #691
    177 Post(s)
    No thread tape or sealant?
    You only have a 233 by the looks. Im not aware of any coil sprung 4.2s coming with the larger rear.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    Hodge (26th March 2016)
  4. #693
    177 Post(s)
    Some of those oil suggestions recommended 4.7L which was the H260, so I got enough oil for that but as it turns out it is the 233. That sorts that out.
    I put a bit of thread tape on, as the oil wasn't anywhere near as dirty as I thought it'd be, I'll run this through for a week maybe and then dump it and put the fresh batch in.
    Now to do the rest, front diff, gear box and transfer. Any recommendations for oil Matt ? This is off the castrol guide.
    Gearbox: CASTROL MANUAL VMX-M 75W-85
    Transfer Case CASTROL ATF DEX III
    Rear Diff/LSD CASTROL AXLE LIMITED SLIP 85W-140
    Front Diff CASTROL AXLE EPX 80W-90
    No specific brands but I highly recommend a gl-4 spec gear oil for the box. I use hi-tech oils 75-90 gl-4. I then just use that in both the transfer case and front diff.
  6. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (2nd April 2016), Hodge (26th March 2016)
  7. #695
    H260 has 12 bolts holding the centre in and the H233 has 11 bolts. Easiest way to tell.
  9. #696
    Even easier than getting under is the compliance plate. Trans axle code is slightly different for a 260
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #697
    Or you can do that. But since he was under there. ..
  12. #698
    He isnt anymore
  13. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (27th March 2016)
  14. #699
    177 Post(s)
    He isnt anymore
    Or just look at the photo I already have on the PC. lol
    Which confirms the gear box and the 3.9 ratios, which out of factory is the 233.
    Bit late now but some weld a 6mm ring around the sump plug to protect
    it from getting beat to death on rocks, just saying
