Just put the money down on a new set of rubbers and rims. Km2's on steelies.
BigRAWesty (9th March 2016), megatexture (10th March 2016)
I bought a wiring loom, new washer bottle and washer motors, and series 1 lights so people stop almost running up my back end when they tail gate me.
50A solid state relay
90-110 psi cut off switch
50 degree thermostat switch.
Small barn door extension bracket..
Next is a compressor switch and led light bar switch.
Bought a "winch in / winch out" carling style switch for "in-cabin" winch control. Not going to wire it up the traditional way. Going to wire it to a warn winch plug and only plug it in when required.
Bazza
Got it today, had an old battery to try and recharge so hooked it up with the blanket flat on the drive at 2.00 pm saw 6 amps on my clip meter.
The high voltage light was on which means the battery if already fully charged, that is not the case. It also doesn't work at all on the Redarc BCDC solar input either.
Give it good test over the weekend and compare it to the folding 120watt panel I have.
Macca
BigRAWesty (10th March 2016), megatexture (10th March 2016)
