Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Boost Pressure
    If you have the vacuum canister on yours, the coke can shaped thing next to the intercooler. Get rid of it and join the two hoses together. These things tend to crack and leak vacuum.
  2. #12
    Chances are being a 2001 model the IC will be leaking big time, still fit your boost gauge by all means but
    start looking for a fully tigged and pressure tested Intercooler. You be surprised the difference it will
    make to your power and EGTs
  3. #13
    Feb 2016
    yeah i will look into it cheers
  4. #14
    I had the bung in the front pipe where it says outlet pipe. The pipe after that short rubber section.
    I read this is the recommended spot due to cooling of the air over the cooler..
    Thats not going affect boost pressure readings. Its more so the most accessible spot on the Direct injection motors.
