Results 11 to 20 of 29
Thread: Zd30 won't accelerate past 90
    Feb 2014
    Townsville
    Thanks for your help three dogs. I am extremely appreciative of you and the other guys that provide so much valuable information and explain it in easy to understand ways.
    When it comes to concreting, I am really bad but when it comes to mechanics, I would make a great concreter.
    So thank you again for all your help.
  2. #12
    Dont give up yet the others wil see this soon and
    have their own idea of whats causing your problem
  3. #13
    Can you hear the turbo working it should be very audible I would think
  4. #14
    Feb 2014
    Townsville
    Yep the turbo is working. Makes quite a whistle when I'm at 80 and just holding the speed. Whilst in neutral I was giving it some to make sure that the vacuum for the turbo was working and could get it easily to 4000 rpm but when driving it struggled to get to 3000.
  5. #15
    477 Post(s)
    Quote Originally Posted by chewindust View Post
    Yeah I was worried about that. The turbo is reasonably new so I hope it isn't buggered. Can you tell me please three dogs where might be the best place to get these things for the NADS?
    Where did the turbo come from bud? I have seen some bad ZD turbos going around.
  6. #16
    477 Post(s)
    Hmm so its a load related issue then maybe. You know anyone with the same motor you can borrow their maf from? Does it do it when cold, hot etc etc. Last time the fuel filter was changed?
    Check the intercooler too for leaks. If its leaking you will lose boost, and more under engine load which in turn will result in less engine power. Oil deposits on the intercooler is a giveaway sign of leaks.
    chewindust (5th March 2016)
  8. #17
    make it a bit easier for you does it have the original Intercooler if the answer is yes and its all oily.
    that may well be your problem or one of them
    Getting it to rev to 4000 rpm doesnt mean the turbo is not or is working
  9. #18
    Feb 2014
    Townsville
    It's a crimped IC and I think it's original, as well as oil in it so I need to flush that out till I get a new one. It also had a heap of oil in the sensor on the IC. Turbo is about 7 years old and was bought brand new. The old one buggered up and had to be replaced.
    The fuel filter is brand new. On that, is there a way to get the fuel primed quicker than standing there for ages priming it with the pump on the filter housing?
    I don't know anyone that has a car like this so I will probably just buy a new Max.
  10. #19
    Feb 2014
    Townsville
    I mean MAF
  11. #20
    One you need to get a tig welded IC asap and then see how you go
    this needs to be changed no matter what so it will be one less thing to worry about.
    Also check the blue hose in the pic they have a habit of blowing off.
  12. The Following User Says Thank You to threedogs For This Useful Post:
