Results 1 to 10 of 11
Thread: Crd losing power up steep hill ? Limp mode
    Feb 2013
    WA
    Hi new to posts but following for years. I have hunted this information everywhere but just getting nowhere.
    I have a unmodified 2008 3ltr patrol auto. The problem is it seems to go into limp mode when I go up steep hills near my home.
    The speed drops off I would be lucky to be doing 15 to 20 kms hour!
    the revs don't go up if I put pedal down, even if I lift foot off and reapply it still does nothing.
    I sometimes have to put it into 1st gear to get up the hill.
    The boost pressure on ultra gauge shows around 12 to 14 psi on average. The power hold switch sometimes comes on by itself and lights up on "hold" also
    Still happens even if I put o/d off
    It seems to happen more in hotter weather and with aircon on.
    Temp on ultra gauge is usually normal at 90 to 93 c. and doesn't vary much
    There are no fault codes on the ultra gauge
    There is oil leaking out of the turbo inlet pipe to intercooler.?
    The air filters have been changed no oil on them and maf sensor appeared clean but I still cleaned with maf cleaner.
    It also happened when I was on beach in 4wd low range goes ok then seem to loose power then comes right?
    I am going to get auto trans a service any body got any ideas? I don't want to take to dealer yet as they could tell me anything.
    Regards
    Paul
    Try swapping the Air con relay with the ECM relay,
    maybe re do a few earth straps as well
    Might want to fit a catch can as well
    Petapaulmary (4th March 2016)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I can't help much but will be following this one. I have an 05 Di and have had similar incidents, but not as often. Trying to pass a truck uphill in hot weather and went into limp mode. It is almost as though the thing can't decide which gear it wants to be in so it gives up and goes into limp. I have found making sure the overdrive is off seems to stop that happening.
    Also only once I stopped in sand, went from hi to low range and when I tried to build a little momentum for the approaching deep sand went into limp mode. Stopped backed up and tried again and no further issues. Try turning the overdrive off and aircon off before hitting the hill and see if that changes things?
    Feb 2013
    WA
    Will try your suggestion, further info does have a catchcan and patrol only has 103000km genuine on it.
    It is doing my head in 😖
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by Petapaulmary View Post
    I know you have but fuel filter done as well
    seems like the intercooler could have a leak
    or hoses
    seals in the turbo maybe
    just my 2c worth
    Jan 2014
    Shepparton VIC
    How was the engine temperature?
    The engine slows down when getting hot, may be good to have a check on the radiator...
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  8. The Following User Says Thank You to MyGU8 For This Useful Post:
    Petapaulmary (5th March 2016)
  9. #7
    Expert Ronin's Avatar
    Brissy
    on my Patrol going up hill with heavy load would cause the semi limp mode , no error code or check engine light would show up.. eventually going to a bigger exhaust fixed it.
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  10. The Following User Says Thank You to Ronin For This Useful Post:
  11. #8
    I too have had similar issues (steep hills or soft sand). It is if the transmission won't drop down and I have to manually drop it down to 1 to get the revs up. I find taking the overdrive off improves things. Also try playing around with that at switch (not too sure what it is called). That too may help.
  12. The Following User Says Thank You to bignev For This Useful Post:
  13. #9
    Feb 2013
    WA
    Hi
    I have changed fuel filter radiator temp really good no dramas, tried with od off still no joy.
    On my boost gauge I have put in just off the turbo it peaked at 20 but the factory fitted one on the tank bear the inlet manifold showed around 17 if that means anything?
    Regards
    paul
  14. #10
    Dec 2015
    WA
    5 Post(s)
    Auto trans running hot?
    Graham
