Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: 4.2 TDi Overheating
    Expert Tonks's Avatar
    ACT
    4.2 TDi Overheating
    Has anyone fitted a UFI fan & hub.
    If so did it help in lowering the temps,
    Tonks
    2004 GU111 4.2 TURBO WAGON, 2" OME SUSPENSION, 33" MTZ's, 3" BEAUDESERT EXHAUST, ARB ROOF RACK, ARB AWNING, BLACK WIDOW DRAW SYSTEM & CARGO BARRIER, DUAL BATTERIES, 12,000lb WINCH, GME UHF, LIGHT FORCE XGT SPOTTIES, BERRIMA DIESEL TUNE.
    177 Post(s)
    Quote Originally Posted by Tonks View Post
    Tonks
    They are apparently ducks nuts . From reading the forum here and the FB pages people swear by them.
    Rocket55 fitted one not long ago . They give out a bit of noise and supposedly take off 5-10kw off your power pool .
    Tapatalked from S6
  3. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Ropes (17th October 2017), Tonks (11th February 2016)
    Expert TuffTD42's Avatar
    Feb 2011
    Central West, NSW
    Tonks
    I have no personnel experiance with the info I am about to give you. Only from my research so take it as you like. I have heard good things about the UFI fan & hub assembly but I also stummbled upon a thread which I can't find now adays where a fellow with a TD42 getting hot fitted a Toyota coaster Fan to the existing Nissan Hub & it fixed his running hot problem. A hell a lot cheaper if it dose work. The part number is Toyota Coaster Bus ZPN-06129. He had to mod the fan do fit. From what I can see looking at a pick on Ebay it just needs a bit of the 4 mounting tabs grouns down a little. from what i have read the TD42 hot thing is an air flow issue. These fans like the UFI fan pul a lot more air. Like I said No experiance with it but $90 compared to $600 I'd give the $90 jobbie a go & see. Then you can let me know if it works incase I start experiancing the running hot problems. Cheers Jono.
    The conspiracy theorists were right!
    Feb 2011
    Central West, NSW
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I'm about to fit this one and add some Toyota silicone oil to my TD42T hub.
    This is the fan used on the Infiniti G35
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    TuffTD42 (16th February 2016)
    476 Post(s)
    Yeah i got one of those too coming soon. But i will do the fan first before i do the yota oil just to see what difference it makes. I wondering how the G35 hub would go too.
    Morayfield, QLD
    I'd be interested to see what clearances you have. I know I have to modify my shroud because it will hit.
    Probably have to move the rad 15mm forward just for a little more peace of mind.
    John
  10. #8
    177 Post(s)
    Are they meant to push more air than standard? Looking at those fins... it may .
    I was talking to UFI today about ordering bits and bobs and the hub/fan they sell , I'm pretty sure from memory he said was $590 ?
    Morayfield, QLD
    It's way more aggressive than the original. Probably hard to see in the pic but they're impressive to look at closely.
    Is that $590 + postage? I don't have that kind of money to throw at a fan and hub. That's 2/3 of the price of the new Mamba turbo I'm buying.
    I'm confident the stock hub will do the job with a little more oil added.
    John
  12. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    Hodge (15th February 2016), mudski (15th February 2016)
  13. #10
    476 Post(s)
    Yeah thats big coin for something, i believe, Eric, you dont need. From my understanding anyway. If you put a bigger pump on, bigger turbo, your fuel usage will increase and therfore create more heat, then it would be worth it. Even mine, it gets to 110c fully loaded and towing the camper, it doesn't conecern me too much, but obviously, i want to keep things cooler.
    I have read and heard so many conflicting stories on radiators too. Some say the oem rad is good, some say a 3 core is better. Then i have heard that a 3 core will restrict air flow and you will not benenfit. Then you have cheap ally 3 cores, right up to PWR radiator for around 11hunge!
