Results 1 to 10 of 15
Thread: GQ Petrol greminlin has returned
    Jul 2011
    Central Queensland
    The gremlin has returned on my Patrol 4.2 efi 96 model, I was having issues with he fuel light coming on and the car not really wanting to run. I have since changed the fuel filter c
    and cleaned the MAF sensor and she was running great. I went to start it this morning and after my wife driving for about 10K's yesterday it is running rough again. It now will start and idle ok, when you go to bring up the revs it has a massive flat spot like it is not getting enough fuel, coughs and carries on and sort of sounds like it is back firing out the throttle body if you give it a stab on the throttle.
    Any ideas would be much appreciated.
    Travo
    Legendary dom14's Avatar
    38 Post(s)
    Sounds like fuel pump issue.
    If you can get hold of a fuel pressure gauge(or vacuum gauge, usually a single unit does both) with a piece of fuel hose & T-piece and test the fuel pressure while trying to rev, can give you an idea if it's a fuel pressure issue.
    Check all visible electrical connections to the fuel pump and clean them accordingly.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    38 Post(s)
    Also, try disconnecting the battery and leaving it all night. Then try again after connecting the battery. This can clear any fault codes in the ECU and give you some idea whether your issue is fault code related.
    Let us know how it goes.
    Cheetah Outreach
    Have a go and refresh your earth straps,
    cant beat a good earth connection lol
  5. #5
    Jul 2011
    Central Queensland
    Gremlin update, must have move to someone else s car, sorry for that. I came home tonight armed with some more info and the awesome manual that i down load from this site (thanks to all involved). What do you know it started straight away no issues, I ran the codes and came up with 55, no issues there. Took her for a drive fro about 15 k to fill up with LPG and it ran perfectly on both petrol and lpg. I took it out to 4200rpm in third pulled all the way no issue.
    Not at all sure what it is but I will keep trying and wait for the engine light to come back on and run the codes again. There may just be something in your comment Threedogs as yesterday and most times I have had issues it has been wet and today it is hot and dry?
    Thanks again for your help
    Travo
  6. #6
    38 Post(s)
    Quote Originally Posted by Travo View Post
    Travo
    Yeah, it's highly likely a problem with fuel pump/pressure, which means electrical.
    Ensuring the earth connections are in tip top condition keeps you out of trouble.
    Check all the wires/connections related to fuel pumping electrics.
    Cheetah Outreach
  7. #7
    Expert billyj's Avatar
    gordon
    sounds like a dead/ dying fuel pump to me
  8. #8
    How about replacing/refreshing your fuel lines, as well as all the vacuum hoses.
    Do them one at a time some you dont run into trouble.
  9. #9
    Jul 2011
    Central Queensland
    Good tip Threedogs I put the original filter back in and had a look at some of the hoses and was thinking same, what are the standard sizes and I will just get a couple of meters of each to start with.
    I have an LRA belly tank, would they have used the standard patrol pump in this set up?
    Travo
  10. #10
    not sure on hose size but would think all aftermarket tank makers
    would use the OE sender unit
