Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Permanently setting up trickle charger.
    I now have one of those 1.5w solar chargers to keep the ride-on mower battery fresh. From what I can gather from this thread is that it is ok to leave it connected to the Patrol for weeks at a time. Has anyone had any problems with doing that?
    Won't hurt anything in the slightest... assuming it has a blocking diode so it won't back feed when the Sun ain't shinin'
  2. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (1st February 2016), mudnut (1st February 2016)
  3. #22
    84 Post(s)
    Yeah, it stated on the package it had a blocking diode. I was just wondering if it would over charge the battery?
    Interesting to note that the open circuit voltage is 21volts
  4. #23
    Goodo... and... yes the open circuit voltage should be 18 ish to 21 ish depending on the technology of the cells regardless of wattage (for 12 Volt nominal Panels that is).
  6. #24
    Expert clubbyr8's Avatar
    Penrith, NSW
    This what I use for my CTEK. They're located in that strip on the centre console. Middle panel monitors the cranking battery and the bottom one monitors the auxiliary battery. Leds give a rough idea of the state of charge. If I need to charge either battery, I just plug the CTEK into the appropriate panel....
    20160202_181835 by Bob Howard, on Flickr
    GROOVY GUVII
  7. The Following 2 Users Say Thank You to clubbyr8 For This Useful Post:
    mudnut (2nd February 2016), Tallion_o7 (25th November 2024)
