Page 49 of 101 FirstFirst ... 4748495051 ... LastLast
Results 481 to 490 of 1003
Thread: Hodge's new 4.2
  1. #481
    177 Post(s)
    So I went about carpetting and modifying the rear draws / fridge system that I got from Mudski. In the end I ended up tapering the front upper area to suit the tapered patrol's rear draws. I carpetted the whole lot , and in the end removed the draw and little slide out table (which i can add back on at any time). I like it the way it is. Not a fan of the draw.
    For a non carpetter and non carpenter I'm impressed how it all turned out.
    Looks great lol
    Dont need a vent hole at the back of the fridge cavity, gunna get hot in there
  3. #483
    177 Post(s)
    There is a hole with a fan I am yet to cut the carpet out for that. The fan will be wired with the compressor maybe so when it is running it'll kick in.
    Tapatalked from S6
  4. The Following User Says Thank You to Hodge For This Useful Post:
    threedogs (16th January 2016)
  5. #484
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Nice work mate, looks like a vey tidy job!
  6. The Following User Says Thank You to Bacho86 For This Useful Post:
    Hodge (16th January 2016)
  7. #485
    Jan 2016
    Nice patrol mate
  8. #486
    177 Post(s)
    Fitted the rear unit in the car. Very very happy !!
    Extension bracket added for the child seat. And cargo barrier brackets will use the same bolt holding the unit down.
    Now just to take out the rear belts and figure out how to best utilize the bolts area previously used for the seats. Might make a plate or something and just cover it.
    Very nice....
    Someone here maybe Threedogs, has a plate to put over where the seats use to be.
  10. The Following User Says Thank You to jay see For This Useful Post:
    Hodge (17th January 2016)
  11. #488
    Yes I have cover plates Eric any colour you want.
    you can then bolt on old tie down points , well thats what ive done
    comes in handy tying gear down
    Plus just poke the belts back down that top slot
    this may be handy too
    http://www.ebay.com.au/itm/361348194...%3AMEBIDX%3AIT
  12. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Hodge (17th January 2016), jay see (17th January 2016)
  13. #489
    177 Post(s)
    Thanks John. I knew someone had them a while ago... I'll grab a set. SMS-ed ya.
    477 Post(s)
    Wow looking good mate!
    Those plates from John is what your after... as for the seat belts. Easiest thing to do is remove the belt guide in the trim, and tuck the entire belt in behind the panel and clip the trim back on.
  15. The Following User Says Thank You to mudski For This Useful Post:
    BigRAWesty (25th January 2016)
