Rocket55 (19th December 2015)
It's half blocked up. I could get it cleaned out and rodded, or I could start again with a fresh 3 core unit.
Cheers Rod
_______________________________________________
Bitumen ...... Another watse of public funds
My Build 2005 TD42TI
Started doing the gearbox mounts tonight and all was going well. Cross member out ready to undo the mounts.
Drivers side out and in, easy
Then the passenger side, 1 bolt out and then this happens, not happy Jan!!!
Cheers Rod
Err thats a bummer. Hope you got some good drill bits and enough room to drill into it.
Your telling me. Theres no reason for it to be that tight, all the others once cracked were pretty much finger tight to get out, I don't get it. I'll try an hit it with a punch and see what happens, if not then start drilling and head up the shop in the morning for some Easy-Outs.
Cheers Rod
Hmm good luck.
That might do for tonight, have to go up the shop later and get some tools and another bolt.
Cheers Rod
What a bastard, at least it's not in a awkward spot.
Not a welcome site broken bolts, good luck.
some freeze spray up the center of hole may help to shrink it a little to help loosen it.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
