Page 39 of 101 FirstFirst ... 3738394041 ... LastLast
Results 381 to 390 of 1003
Thread: Hodge's new 4.2
  1. #381
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    You read my mind John. I was wondering if i could use an Ecu talk. I should have kept mine...
    There's a lot of info I no longer get (nor need) on mine such as timing & MAF, O2, etc. anything that related to EFI but I'm happy to get real engine temps & volts without having to add gauges & sensors. I also used it to set my TPS and it will show if my TPS has an issue.
    Other big advantage for me is that I can still do full auto trans diagnostics via Ecutalk.
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (18th December 2015)
  3. #382
    Aug 2014
    Perth
    10 Post(s)
    Ok next dumb question where is the port to plug in the cable
  4. #383
    Should be under the steering coloumn
  5. The Following User Says Thank You to threedogs For This Useful Post:
    gubigfish (18th December 2015)
  6. #384
    North brissy
    Just at the edge of the plastic trim that is under the steering wheel. Its a white plug.
  7. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    gubigfish (18th December 2015), Hodge (18th December 2015)
  8. #385
    476 Post(s)
    Bugger. now I want an ECU talk again to read my water temps...
  9. #386
    176 Post(s)
    Did you read my post above does yours have provision for that ?
    Workmates 2002 4.2 doesn't. It's not a tdi.
    Just in case you buy it lol
    Tapatalked from S6
    Morayfield, QLD
    13 Post(s)
    Did you keep your ZD30 ECU in place during the conversion?
    John
  11. #388
    @ Eric does your centre,, console right of the gear stick have any switches there?
  12. #389
    176 Post(s)
    Yeah mate. That antenna switch is doing nothing. It'll be replace with front locker switch early next month...
    Tapatalked from S6
    You just mounted the switches ,,I brought the inserts that the switches fit in.
    Good to see there is enough depth for switches, Thanks for that>
    Read Stropp's thread on the Ecu-Talk when you get time.
    Putting 3 there too, winch isolation switch, front locker and compressor
    http://www.ebay.com.au/itm/ARB-Carli...jXGB9Y2A_83Wrw
    I used these Baintech Volt gauges to monitor my start and Aux battery,
    the other is on the other side of the head unit, IMO I think its a waste putting a
    volt gauge in the pillar pod
    AND If you dont smoke or use the ash tray you can make
    a new lid and fit some more gauges there
  14. The Following User Says Thank You to threedogs For This Useful Post:
