Results 1 to 10 of 16
Thread: Which diffs interchange?
    2006, TD42ti wagon with 285 tyres. I want to swap diffs from 3.9s to 4.1s. I don't want to fork out money for a 4.1 only to find it doesn't fit and I've done my dough. Can someone clearly tell me how I can recognise/ID a 4.1 diff that will fit straight into where my 3.9s came from before I buy it? I don't care how long winded your explanation is so long as it's helpful. Hoping someone can help, Deevo.
    476 Post(s)
    You need to know what rear diff you have first. H260 or the smaller H233b. Just count the number of bolts holding the centre in to tell. H260 has 12 and the H233 has 11.
    Fronts are the same. Dont get centres from a ute. Even if they are the same centres as you. Because the utes use a smaller axle spline in the rears. So they must be from a wagon.
    Otherwise its very straight forward.
  3. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Deevo (14th December 2015), dom14 (2nd February 2016)
    334 Post(s)
    You have a H233 in your GUIV TD42Ti
  5. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Deevo (14th December 2015), dom14 (2nd February 2016), mudski (13th December 2015)
    476 Post(s)
    Easy then. Just look for H233 front and rears. But not from a ute though...
    Thats 'cause Utes are special and awesome and need lots of hugs so we don't play well with Wank... I mean Wagons
    476 Post(s)
    And special people drive utes....lol
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (14th December 2015), the evil twin (13th December 2015)
  10. #7
    ROFL, yep, only need two seats in my ride, one for me and one for Chewy.
    Altho Chewy does tend to eat bits and pieces of his... but I don't mind... there is just no negotiating with 50 Kilos of pissed off Alsatian
  11. The Following User Says Thank You to the evil twin For This Useful Post:
    mudski (14th December 2015)
  12. #8
    did you say special or special needs ppl drive utes ? LOL
  13. #9
    Anywho..
    If the diff is still in the car you will see on the Vin number what ratio it is.
    Given that the diffs are original.
    If they are out then simply count the main crown gear teeth and devide that by the smaller pinion gear teeth..
    That'll give you the ratio.
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
  15. #10
    Thanks for that Mudski. My diffs are HG39 with 11 bolts so therefore I have H233 diffs with a 3.9:1 ratio. They are the original diffs (I've had the car since new). If I'm understanding you correctly, this means I can safely buy any 4.1 diff and expect it to bolt straight into the respective banjo (whether it be front or rear) providing it is NOT out of a ute. Correct? Thanks for your help -it's what I was after.
