Results 1 to 10 of 12
Thread: Strap to bull bar- What for?
    Whyalla SA
    On my GU I have a Nissan Bullbar and at the back are 2 straps. These are bolted back to areas that are part of the bullbar attachments (?). On the bull bar they are bolted on to the winch mount area; about 25-30 mm above the top 2 mount points for the winch.
    I cant see how these could even work with as a support due to a tension load on the winch due to the way they are bolted on.
    What do these 2 straps actually do, if anything in besides get in the way?
    Possibly a brace to assist the crush zone on the chassis when a winch is fitted
    got airbags?
    334 Post(s)
    I mounted my Dolenoid the the drivers side one.
    Whyalla SA
    got airbags?
    Has airbags, but due to the shape it does not make sense airbag or not. Anyway the bull bar is on the rush zone and hence will automatically cause airbag inflation.
    As these are not straight but already part curved they have no compression resistance at all.
    The bar is rated air bag Nissan compliment by Mr Ni$$an.
  6. #6
    Whyalla SA
    Winch mounts straight on bulbar so no mounting plates like the GQ.
  7. #7
    Yep, winch mounts to bar and then under load the straps will take part the load from the bar to the chassis and the crush zone will take the rest..
    They are curved so they don't resist compression in a crash.
    Just my guess anyways
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MudRunnerTD (5th December 2015)
  9. #8
    334 Post(s)
    I agree. Thought that also but on the phone couldn't be shagged typing it. I think that's Spot on.
  10. #9
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Maybe they are to help stop sideways movement of the bar in a crash, to make it collapse the crumple zone more square on and activate the airbags?
    For example if something clipped the corner of the bar from 90 degrees instead of head on.
    tappin from tassie
    Hello from Under Down Under!
  11. The Following User Says Thank You to taslucas For This Useful Post:
    BigRAWesty (5th December 2015)
  12. #10
    Jul 2013
    3 Post(s)
    Looks like extra support for when a winch is under load when in use. Just a guess.
