Results 1 to 10 of 16
Thread: ADJUSTING BONNET SQUIRTERS {tom cats]
    FYI if your having trouble with your squirters no squirting water in the right spot,,,,?
    Go grab a sewing needle [small] insert it into the squirter jet and move till you get the
    right angle,
    Also sometimes small peebles will get trapped behind the squirter,,,so just remove the clear tubing from behind
    and that should clear them, its a good idea to push the needle into all the holes as sometimes mud partially blocks them.
    Its the same for the rear one as well
  2. The Following User Says Thank You to threedogs For This Useful Post:
    the evil twin (19th November 2015)
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Haha my passenger one has literally just stopped squirting and i was thinking to myself i better do something about it. The old needle is exactly how I've been adjusting mine and cleaning the nozzle. Just need to find the motivations.... a job for next week i think.
  4. The Following User Says Thank You to sooty_10 For This Useful Post:
    threedogs (19th November 2015)
    brisbane
    I tried swapping mine for ones off my hilux as they have a fan spray pattern but the gu's pump was not strong enough and it just dribbled out
  6. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    Maxhead (19th November 2015), mudski (19th November 2015)
  7. #4
    My water bottle leaks empty within a couple of hours so I just don't bother... Lmao
  8. #5
    I just use a pump bottle filled with water, stick my hand out the window and squirt the windscreen......... i think my washer pumps are dead
  9. #6
    477 Post(s)
    Need a new check valve for it mate.
  10. #7
    Yeah that's what I do now lol... My pumps are okay but the seals on the pumps are knackered
  11. #8
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Just don't get caught using the wifes needles
  12. The Following User Says Thank You to Sir Roofy For This Useful Post:
  13. #9
    Nope it leaks from the pumps.
  14. #10
    Expert Skitzyrex's Avatar
    Jul 2013
    Only did this just yesterday.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
