Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 58
Thread: A Guide on installing your own remote central locking in under 20 minutes
  1. #31
    Quote Originally Posted by Shazlic View Post
    Couldn't get the SCA kit to work, luckily I tested it before cutting into it's loom so returned it and got a 9500 winch instead
    i wasted some $$$ on a jaycar job before i went to jbhifi like mudski suggested in the first place and bought him one lol. do yourself a favour and get one of thsoe instead.
  2. #32
    476 Post(s)
    Yep the Warlock kit is great value. I've have had it in there maybe two years? Or roughly when i made this thread, and the remote still works.
  3. The Following User Says Thank You to mudski For This Useful Post:
    rusty_nail (6th October 2015)
  4. #33
    Hardcore
    central coast nsw
    Having a little trouble trying to fit steel mate alarm into 2002 gu.
    My oem remote system was working fine but wanting to add the alarm.
    And utilize the existing wiring for the central lock side of things.
    going buy the wires feeding to oem central lock remote unit top right behind glove box, colours are the same as previously described.
    oem plug
    white = 12v pos,
    2xgreen =2x indicators,
    2xblue = 2xactuators.
    steelmate
    2x yellow =12v pos
    2x brown = indicators
    white and white/black = actuators.
    Iv'e hooked up for pos actuators and not the neg ones.
    obviously power & earth are connected.
    The drivers door is a master right?
    and the oem remote plug is connected to it, why would't it be!
    press new remote lock/unlock and blinkers flash= working.
    test light is showing white wires are active BUT
    the lock/unlock actuators wont activate in either direction.
    Nothing is happening!
    put the oem remote back in, works just fine.
    think I have a dud steel mate alarm.
    thankfully I hadn't hook up all the other functions for the alarm, ignition cut etc as it appears that may of been a waste of time.
    any one have any ideas?????
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  5. #34
    476 Post(s)
    The drivers door is the master....
    As for the trigger wires. Try the neg triggers. It might be different for your model car and kit.
  6. #35
    Patrol God Stropp's Avatar
    36 Post(s)
    I have a warlock ac100 system but with just one central popper, the young bloke got it on special for $28 😳 it's been in for a while and now it's stopped working so I will change it out for a new one as I have three spares. The unit tries to move and clicks but won't open so I will change it so hopefully it works.
  7. #36
    Hardcore
    central coast nsw
    I'll check the output of oem unit asap.
    steel mate kit can be either pos or neg.
    was just going by pos being the way things were, see soon.
  8. #37
    Hi All,
    Bit of a thread dig I know but Im about to embark on same project. I have pictures below of my alarm wiring, and they way I THINK I should wire it. My questions are:
    Does the wiring diagram look ok?
    Should there be an earth for the door lock actuators?
    Thanks in advance.
  9. #38
    476 Post(s)
    Looks fine to me. Hard to tell on my phone though.
  10. #39
    Thanks....................
  11. #40
    Quote Originally Posted by shaun100 View Post
    Hi All,
    Thanks in advance.
    What kind of unit are you using. I really need to pull my finger out and do this...
