Results 1 to 10 of 11
Thread: Cheap solar panel
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Cheap solar panel
    Hi all,
    As my patrol is no longer my daily driver I have been thinking of way to keep the battery topped up in between runs. I have a 240v charger that will trickle charge but I don't have any power points where I keep the car but also don't want to run a huge extension lead out all the time either.
    So that got me thinking about solar. This panel specifically
    http://www.supercheapauto.com.au/onl...ecommendations
    I have a super crap gift card I need to use so ideally that would be good. The panel won't need to be high out put as it just to keep the battery up, with almost nothing running off it (alarm and elec rust protect).
    Is something like this going to work or am I just going to have to spend another few hundred on getting a good regulator making the cheap panel worth less?
    I really I don't want to have to spend heaps doing this.
    Thanks in advance.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    That would be quite adequate for keeping your Battery topped up.
  3. The Following User Says Thank You to Bob For This Useful Post:
    lhurley (27th September 2015)
    X 2 it will put about .5 ah back in and keep your battery busy
    178 Post(s)
    Yes it will do the job provided the alarm & rust protector don’t use more power than the panel can provide.
    However it is quite expensive for what it is.
    Compare to this http://www.ebay.com.au/itm/10W-12V-S...item4af12b9a64
  7. The Following User Says Thank You to Cuppa For This Useful Post:
  8. #5
    http://www.ebay.com.au/itm/10W-12V-P...item51d38bb11a
    Plenty of affordable panels out there.
    save the Super Cheap card for service items when on specials
  10. #6
    Jul 2015
    Camden NSW
    6 Post(s)
    I just bought a 10w panel to keep my camper trailer battery charged. Ebay for $32 with regulator and free post and it looks identical to the supercheap one. ( the small ones are probably all the same )
    Bazza.
  11. The Following User Says Thank You to bazzaboy For This Useful Post:
  12. #7
    Quote Originally Posted by bazzaboy View Post
    Bazza.
    Hey mate, got a link? Been thinking about this for a while because my car just sits around for weeks at a time
  13. The Following User Says Thank You to Winnie For This Useful Post:
  14. #8
    That last link of mine Winnie would suit your needs and affordable too
    http://www.ebay.com.au/itm/10W-12V-P...324&rmvSB=true
    Make a lead onto the bar or somewhere out of the way directly to your battery so you just plug it in
  15. The Following User Says Thank You to threedogs For This Useful Post:
  16. #9
    178 Post(s)
    http://www.ebay.com.au/itm/10W-12V-Portable-SOLAR-TRICKLE-BATTERY-CHARGER-for-car-RV-camp-marine-atv-/351441498394?hash=item51d38bb11a&clk_rvr_id=902105 781324&rmvSB=true
    No mention of a regulator on that one. I did once have a battery boil dry when left connected to a small unregulated panel over a long period of time - admittedly a much smaller motorcycle battery - but my preference would be for a regulator, even if only a cheapie. Hence the panel I linked to earlier in the thread from a seller I know to be reputable.
    It is also possible for a battery to discharge through a panel at night. Connection via a regulator will prevent this occurring.
  17. The Following User Says Thank You to Cuppa For This Useful Post:
  18. #10
    I'm the same as Winnie, car can sit for a while and is killing my battery but all I can find on supercheap site is a little 4w unit with no regulator so you may as well buy cuppas link for that money.
  19. The Following User Says Thank You to AB For This Useful Post:
    Winnie (29th September 2015)
