Page 2 of 15 FirstFirst 1234 ... LastLast
Results 11 to 20 of 141
Thread: Cuppa's Camper
    Feb 2011
    Shed
    45 Post(s)
    Lookn forward to watching the build up cuppa
  2. #12
    Patrol Freak Dark 1's Avatar
    Sep 2010
    Mundaring, Perth
    Looks tops cuppa, I want one.
    Watch out there's a Poo "Yota" lurking in the shadows !
  3. #13
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Looking good cuppa,ideal for getting wood with excellent workhorses
  4. #14
    176 Post(s)
    I'm jealous already. Can you tell me a bit about the stuff and their prices. PM me if you prefer.
    Ross
    PS... The tap on the L/H underneath water tank.... is that an addition or came with the truck? Mine came with a plastic thing thats hard to turn off/on and leaks if not turned off properly.
    PSS. Have you ripped out any of the Telstra wiring yet? If so, what?
    Hi Ross,
    Monitor
    Camera
    The tap came with the truck, but needs replacing 'cos it drips too.
    I did rip out a number of Telstra wires when running the cable for the camera. Behind the glove box was an antenna (small nextg type), & several similar cables that had been cut. These ran down the passenger side pillar behind the plastic trim, down to the floor & out through a large grommet to the canopy.
    Does yours have these switches on the canopy doors (See pic below)? Any idea where the wires from them go to?
    I note on the power distribution box in the canopy the andersen plug is rated at 35amps continuous. Have you looked at the wiring behind yours? If not I'd suggest you do before plugging too much into it. I reckon the main supply cable from the 2nd battery in the engine compartment, is way too light for the job. I intend to upgrade it.
    regards
    Cuppa
  5. The Following User Says Thank You to Cuppa For This Useful Post:
    DX grunt (7th April 2011)
  6. #15
    WA Wheatbelt
    23 Post(s)
    Is your second battery a deep cycle or a cranker?
  7. #16
    176 Post(s)
    I haven't removed it yet so I'm not sure, but it is a 'wet' battery. I suspect it is just a cranker. I intend to fit a third, an AGM in the canopy.
    Cuppa
  8. The Following User Says Thank You to Cuppa For This Useful Post:
  9. #17
    WA Wheatbelt
    23 Post(s)
    On mine, the door alarm wires end up on the dash on the right hand side of the steering wheel, where there's a big yellow light and a loud buzzer. I can have the doors closed but not locked and the alarm goes off, or the doors can be open and the alarm goes off. Don't know where they start, but if you work backwards, it'll probably help.
    Ross
  10. The Following User Says Thank You to DX grunt For This Useful Post:
    Cuppa (7th April 2011)
  11. #18
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Top set up there mate. keep the build up pics coming
    ________________________
    ______ 2017 D-Max _______
  12. #19
    great start Cuppa, keep it up mate.
  13. #20
    176 Post(s)
    Things have been slow on the camper build, & will likely remain so as we will be heading off to the UK soon, back mid August.
    I managed to trace the wires for the canopy door alarms, & found the wire cut at the buzzer. I soldered on a short length of wire & re-connected. All working now - worthwhile I think as I have already driven off with the passenger side up!
    I also fitted an 'Engine Saver' Low coolant alarm today - easy to fit - sensor replaces the bleed fitting on the thermostat housing. Expensive for what it is, but cheap for what it does - peace of mind.
    I have also bought a secondhand Shippshape rooftop tent with full awning but haven't fitted it yet. I need some roof bars, The 1500mm heavy duty Rhino crossbars would be perfect, but I'm trying to find a cheaper alternative first. Once fitted I'll have to get the awning made a little longer, seems the canopy is higher than most.
    Cuppa
