Results 1 to 10 of 16
Thread: GU converting auto hubs to manual
    Mar 2013
    Will the manual hubs from my old GQ fit as a replacement to the auto hubs on a series 2 GU?
    Thanks in advance
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Yes should be a straight bolt up
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
    Aug 2010
    adelaide
    if you run into trouble read this
    http://www.nissanpatrol.com.au/forum...l-hubs-into-GU
    if you dont swap them then the gu ones can be converted in this thread by ynot
    http://www.nissanpatrol.com.au/forum...bs+manual+hubs
    OH LEATHER IS NICE
    476 Post(s)
    Just bang out the auto locking plate on the GU auto ones. Then they are strong, manual hubs. Takes about five minutes a side, including removal of the hub from the car. Flat screw driver and lever out the first plate you see on the inside section of the hub.
    Rocket55 (4th August 2015)
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    This is a job I just haven't gotten around to yet. I want it mainly for reversing trailers.
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  7. The Following User Says Thank You to Rocket55 For This Useful Post:
    Hodge (4th August 2015)
    176 Post(s)
    Yes another little thing I will have to attack my self.
    Jun 2015
    Penrith, NSW
    is there a good reason why to swap to a manual hub instead of leaving the auto ones in, I know a mate who did years ago on a Hilux.
  10. #8
    Sydney
    3 Post(s)
    Sometimes the auto hubs when left in the auto position can unlock themselves when changing direction and then grab when you gun it again. This can shock the hub etc. I wouldn't say it's a common thing but it can happen.
    Cheers Rod
  11. The Following User Says Thank You to Rocket55 For This Useful Post:
    Stevelb21 (4th August 2015)
  12. #9
    476 Post(s)
    Yeah when I first got my Patrol on the odd occasion I would back out of the driveway, start to move forward and click click click. Gave me the shoits so out came the screw driver and levered those plates out. Done both sides in less than a stubbie.
    Rocket55 (5th August 2015)
  14. #10
    Sydney
    3 Post(s)
    You don't need to jack it up or pull the tyre off do you?? Just undo the 6 or 8 cap bolts and pull the hub off??
    Cheers Rod
