Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 79
Thread: Runva 11Xp Install to Genuine Nissan Bar
  1. #31
    Expert Smoothrun's Avatar
    Dec 2012
    Vic Melb
    It's holding up well so far - but I haven't done any extreme corrugations or anything yet. Just one of those things to keep an eye on
    I recon itll be ok, I fitted mine too close to the grille and couldnt put the remote plug in, , worked out good because i simply took it off and bent the mount at a 45, worked out great cos now it rests solid on the winch housing too. doesnt even flex, ill keep aan eye on that and pack it up if the need arised.
    Lifes a journey not a destination.
  2. #32
    Dec 2012
    Vic Melb
    I noticed today that there was a light blue cable sittin in the control box, I recon it might be the cordless remote lead, I didnt do it but if I have dramas with the remote first thing ill do is pull that lead outa the control box.
  3. #33
    Dec 2012
    Vic Melb
    OK after family left I jumped back onto it to finish the wiring, Not sure what ive done or need to do, but the winch is winding in when selecting out on the remote, and visa versa, any thoughts anyone, do i need to change the blue and yellow leads, cos I turned it over, change the rope on the spool. Im stumped, please help.
  4. #34
    That blue cable is the antenna for the remote. It is wired to a separate unit which feeds the solenoid along side of the plug.
    If you open the unit up you will see 2 red wires running off the positive solenoid post. Take them off and run them threw a switch in the cab. This will switch on and off the control units.
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Smoothrun (30th January 2015)
  6. #35
    Patrol Guru Rocket55's Avatar
    Sydney
    I just followed the standard colour coding and it all worked the right way. Double check you have gone blue to blue and yellow to yellow.
    Cheers Rod
    My Build 2005 TD42TI
  7. The Following User Says Thank You to Rocket55 For This Useful Post:
  8. #36
    Dec 2012
    Vic Melb
    Sound good, Ill do that, thanks mate
  9. #37
    Dec 2012
    Vic Melb
    Quote Originally Posted by Rocket55 View Post
    Yep, Checked that already Rocket, The rope is drawing from the top of the spool as I needed, all I did was turn the winch over which shouldnt make any difference to in or out. control lead only goes in one way so its not that. Best I can do is email Runva,
    Edit,,,
    Just for the record i tested it with the wireless remote and in was in, out was out, gotta be a stuff up on the hard remote,remote socket on control panel, or the wireless remotes incorrect lol, gotta put all possibilities out there.
    Have emailed Runva should geta a reply tomorrow or Sunday.
  10. #38
    Dec 2012
    Vic Melb
    Thought id update some pics for reference
    These show the bbar support brackets side brackets ive been mentioning, i simply removed it drilled the holes and used stainless bolts
    I also used longer bolts underneath for the control box
    I have more pics but these show the positioning, the last one has now changed as I bent it a little and thats made it more solid, just didnt taka a pic yet.
  11. The Following User Says Thank You to Smoothrun For This Useful Post:
    Bacho86 (31st January 2015)
  12. #39
    Feb 2014
    Seen a post elsewhere that the Runva 11xp is selling for $600 which includes free install as well from Shents Automotive at North Wyong NSW. Not a bad deal really.
    Cheers,
    Leo
  13. #40
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Quote Originally Posted by Smoothrun View Post
    Nice work mate, looks like it came together nicely - hopefully you get the controller issues sorted out quickly!
  14. The Following User Says Thank You to Bacho86 For This Useful Post:
    Smoothrun (31st January 2015)
