Page 13 of 21 FirstFirst ... 1112131415 ... LastLast
Results 121 to 130 of 203
Thread: Forum Faults and Information
  1. #121
    Bump, did this tell you anything?
    Is there anything I can try?
    Sorry mate, I did some research for you from possible faults with the forum but I got lost.
    There can be a fault with the forums prefixes as above on certain threads but it would effect everyone, not just you so it can't be that problem.
    It's only just the happy thread isn't it, nothing else?
    Can you try to go to happy thread when you are not signed in, does that work?
  2. #122
    I tried a simple fix, try and go there now and see what happens?
    Not through the links in this thread, go to the thread under general chat or what's new.
  3. #123
    .......... TPC's Avatar
    63 Post(s)
    No worries mate, I know you have plenty keeping you busy.
    The happy thread is the only one I have had this problem with and it does work if I am not logged in.
    Don't spend too much time on it as it is only me and I don't have to be happy.
  4. #124
    63 Post(s)
    Still not working.
  5. #125
    Ok, let me try something else tomorrow morning mate. I have another idea to rebuild the prefixes but I just want to make sure I don't rebuild the entire forum and stuff it...lol
  6. #126
    63 Post(s)
    Don't do anything risky and break the forum again, they will crucify both of us.
  7. #127
    63 Post(s)
    AB I still have the problem where I cannot view the Happy Thread, if you get bored and have nothing else to do you could have another look to at it.
    If you are too busy don't worry about it.
    Internal Server Error
    The server encountered an internal error or misconfiguration and was unable to complete your request.
    Please contact the server administrator, webmaster@nissanpatrol.com.au and inform them of the time the error occurred, and anything you might have done that may have caused the error.
    More information about this error may be available in the server error log.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    Apache/2.2.29 (Unix) mod_ssl/2.2.29 OpenSSL/1.0.1e-fips mod_bwlimited/1.4 mod_fcgid/2.3.9 Server at www.nissanpatrol.com.au Port 80
  8. #128
    63 Post(s)
    Don't worry, I got it working.
    I went into my forum settings and started changing random things to see if they would make any difference and found the following setting was causing the problem, changed it to standard editor and it works.
  9. The Following User Says Thank You to TPC For This Useful Post:
    AB (6th February 2015)
  10. #129
    That's strange mate, ill check that out tonight when I get home.
  11. #130
    AB have you broken the forum/tapatalk again?????
    any one else having issues with the forum loading on Tapatalk?
    Keeps coming up with "Failed to Connect" message.............. do not have problems with viewing other forums on Tapatalk though
