Do as you’ve suggested, plus add MR’s suggestion for an Anderson plug on fridge.
I’m not sure what current your compressor draws, but if it’s anywhere close to 40 amps, then putting a higher amp fuse at the battery would be worthwhile otherwise you run the possibility of blowing it if you ever run something else at the same time as the compressor.
Unless you have a very small & super efficient fridge it will most likely draw more than you suggest. Your figures look more like ‘average’ draw to me (i.e. taking into account the off cycle, & averaging total use throughout the 24 hour period & dividing by 24. I’d guess when running 3.5amps to 5 amps would be more likely. A 7.5 amp fuse should suffice. If it blows on start up, put a 10 amp one in.
Something worth considering is to use circuit breakers rather than fuses. Over time & in mobile situations like ours where vibration is part of the equation they are safer & more reliable. Lots of instances of blade fuses becoming high resistance over time & melting, with fire being a potential result. I don’t know why but this seems more common in the multi fuse blocks. Loads of people will tell you that they have used these multi fuse blocks without problem.... and they have, but I have seen & heard of plenty occasions where catastrophe or near catastrophe has occurred. (From melted fuses & wire insulation to complete loss of vehicle). Circuit breakers come in a number of ‘flavours’. I like the type that are switched, as they double as circuit protection & on/off switches, & don’t require spare fuses to be carried.
If you want to stick with fuses then this sort of ‘resettable fuse’ gives a little extra convenience. They are available in a variety of amperage values.
http://www.ebay.com.au/itm/NARVA-557...item33925c8f3c
