Results 1 to 10 of 15
Thread: automatic climate control
    Beginner inge.t's Avatar
    Jul 2014
    Norway
    Hi,
    I'm currently experiencing problems with my automatic climate control on my Patrol Y61.
    in automatic it will go on full blast heating the cabin when engine temp has risen a bit. When temps set to be 18 degrees C, then it will be full blast cooling the cabin.
    The self diagnose on the unit does not show any faults.
    could it be the temp sensor in the car being a bit funny?
    looking forward to your point of views
    Best regards from Norway
    Inge Thormodsen
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Hi Ingre,
    Does the interior fan run at full speed when the climate control panel is switched off?.
    Can you manually adjust the interior fan speed?
    Jul 2014
    Norway
    I can manually adjust the fan, and it is not running when it is switched off
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    You should be able to check the temp sensor reading via the self diagnoses.
    What year model and engine do you have?
    Jul 2014
    Norway
    2001 model GR 3.0 DI
  6. #6
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I will have a look at the manual when I get to my other computer a bit later tonight.
    Have you checked the ambient temp sensor? How long has this problem been happening for? Has the vehicle been involved recently in an accident?
  7. #7
    Jul 2014
    Norway
    no, I have not checked the ambient sensor, is that the one in front of the radiator?
    No accidents, happened abt 3 months ago. was OK for shorter periods, but not working at all now.
  8. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yes is the sensor in front of the radiator, between the radiator and front grill.
  9. The Following User Says Thank You to Yendor For This Useful Post:
    inge.t (16th September 2014)
  10. #9
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    When you have the climate control set to manual hot, does it blow hot air out the vents?
    When you have the climate control set to manual cold, does it blow cold air out the vents?
  11. #10
    Jul 2014
    Norway
    yes, but went out and checked again now, had failure code 22, and that should be the in- vehicle sensor if I'm correct?
