Results 1 to 10 of 16
Thread: instrument cluster troubles
    sunshine coast
    I am trying to sort out multiple troubles with my cluster in my 91 tb42 I bought a cluster off a 92 model carby and it doesn't plug up so rather than cut a patch lead to suit I am trying to fix my old one
    my tacho I got working today (loose wire at coil)
    oil pressure is working (didnt need to touch) got a pressure reg a year ago
    fuel guage only half working (halfway is empty) 72litre belly tank
    volt metre not working where does its remote wire to (I have dual batteries could be a removed wire or is there a fuse or relay for it)
    my speedo I am sure is wrong (out by 10-15 kph)
    Any help would be great cause so far none of the problems have been in the cluster itself
    sunshine coast
    Oh and temp doesn't work either (I wired in a pod gauge for that)
    334 Post(s)
    Mudnut is your man I reckon mate.
    sunshine coast
    I got 3 clusters beforefinding out they are different
    Apr 2011
    Melton
    Once you have 25 posts you can download the manual - there are 3 versions of the dash listed - type a, b & C
  6. #6
    84 Post(s)
    G,day, wannabe. Have a look at this thread for info about adjusting the speedo :
    http://www.nissanpatrol.com.au/forum...=adjust+speedo
    And this to check the wiring too the speedo:
    http://www.nissanpatrol.com.au/forum...peed-sometimes
    There is some simple tests to check the Fuel Sender in the manual.
    The sender should range from 4.3 to 5.7 ohms at FULL. 74.3 to 84.8 ohms at EMPTY.
    The wiring to the voltmeter is a yellow/red wire (ignition) and it supplies the speedo, fuel gauge via the printed circuit on the back of the cluster. This is a TB42E gauge cluster. The purple arrow, (under the yellow arrow) should be the ignition wire that supplies the voltmeter.
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    MudRunnerTD (28th July 2014), wannabeturboed (28th July 2014)
  8. #7
    Sounds like your fuel sender might be the culprit for your fuel gauge issues. Also what size tyres are you running, these will change the speedo, as will different diff ratios.
  9. #8
    84 Post(s)
    You might be able to swap various gauges from your spare clusters, too. Once you pop the shroud and clear cover off, it is relatively simple to unscrew them and take them out. What are you going to do with the spare gauge clusters?
  10. #9
    sunshine coast
    I have spent the evening pulling the clusters apart and have gotten everything working again . Basically all the gauges were buggered and I had already changed all the senders the dates on all my gauges eere dated 11/09/91 and the good working cluetrr I got was a 11/91 one so didnt fit so I pulled it apart and used the gauges in my casing (not the speedo or the tacho though cause they are different screw fitting)
  11. #10
    sunshine coast
    I dont have any plans with the spare clusters but I wont toss them
