Results 1 to 10 of 18
Thread: Brisk High Performance Spark Plugs
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, anyone using this type of spark plugs from the UK called Brisk High Performance Spark Plugs. I have ordered some as my GU is on LPG . have a look and tell what you think regards Alex
    http://www.ebay.co.uk/itm/6x-Nissan-...:X:RTQ:GB:1123
    Jul 2014
    Auckland,NZ
    Are you running dedicated LPG or duel fuel? How do you find the vehicle performs on LPG?
    Lee
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by sprdad View Post
    Lee
    Hi Lee, at the moment I fine the LPG performs better than petrol and I'm up for changing my spark plugs , So I.m trying something different regards Alex
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    1999 GU 4500 dual fuel
    Il dado è tratto
    Nov 2011
    Rupanyup, 3388, VIC
    Hi NP99 , your link not working, item has been moved regards Alex
  6. #6
    Feb 2013
    Broadford VIC
    Quote Originally Posted by altech View Post
    Thanks mate, not sure what's happened. It was same plug but cheaper ...
    Il dado è tratto
  7. #7
    Hardcore
    central coast nsw
    According to wiki
    Iridium is the most stable of All metals.
    Stable even at 2000 deg C.
    where silver melts at approx 900 deg C,
    silver plug claims don't make much sense.
    I've been using iridium for 10 years ,never a problem.
    set gap and forget, never had to adjust it yet in 2 cars running iridium plugs.
    GQ tb4.2 after 40000 k on lpg and tip wear non existent.
    And a full set of plugs for very similar money.
    be interested to see how ya go, some feed back will you, thanks.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  8. #8
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by Robo View Post
    According to wiki
    Well Robo. car does running alittle better than be4 , but this is after I did the tappers which has been 2 years last done . still getting around 400ks on 90 litres lpg , but I did notice when I switched it over to petrol could tell that I did it and back to lpg . Winner :-) regards Alex
  9. #9
    Hardcore
    central coast nsw
    Good stuff, get back in 5000k and let us know how gap is going will ya.
    cheers
  10. #10
    Nov 2011
    Rupanyup, 3388, VIC
    cheers
    Gap in spark plug did you mean as there is none. regards Alex
